Hi all,
I would like to get the following code (Perfectly working with my setup), modified to working in ' dot' mode; I mean one LED will jump according to the Audio. Can anybody help me Pls.
also if possible, in a different coding, the starting point from center to both ends 1...0...1
Please, help. (My project will display different animation by clicking a button).
#define N_PIXELS 10 // Number of LEDs
#define MIC_PIN A0 // Microphone is attached to this analog pin
#define DC_OFFSET 0 // DC offset in mic signal - if unusure, leave 0
#define NOISE 10 // Noise/hum/interference in mic signal
#define SAMPLES 60 // Length of buffer for dynamic level adjustment
#define TOP (N_PIXELS + 2) // Allow dot to go slightly off scale
#define PEAK_FALL 5 // Rate of peak falling dot
const int led[] = {2,3,4,5,6,7,8,9,10,11};
byte
peak = 0, // Used for falling dot
dotCount = 0, // Frame counter for delaying dot-falling speed
volCount = 0; // Frame counter for storing past volume data
int
vol[SAMPLES], // Collection of prior volume samples
lvl = 10, // Current "dampened" audio level
minLvlAvg = 0, // For dynamic adjustment of graph low & high
maxLvlAvg = 512;
analogReference(EXTERNAL);
memset(vol, 0, sizeof(vol));
for(int i=0; i<N_PIXELS; i++)
pinMode(led[i],OUTPUT);
uint8_t i;
uint16_t minLvl, maxLvl;
int n, height;
n = analogRead(MIC_PIN); // Raw reading from mic
n = abs(n - 512 - DC_OFFSET); // Center on zero
n = (n <= NOISE) ? 0 : (n - NOISE); // Remove noise/hum
lvl = ((lvl * 7) + n) >> 3; // "Dampened" reading (else looks twitchy)
// Calculate bar height based on dynamic min/max levels (fixed point):
height = TOP * (lvl - minLvlAvg) / (long)(maxLvlAvg - minLvlAvg);
if(height < 0L) height = 0; // Clip output
else if(height > TOP) height = TOP;
if(height > peak) peak = height; // Keep 'peak' dot at top
for(i=0; i<N_PIXELS; i++)
if(i < height)
digitalWrite(led[i], HIGH);
delay (2);
digitalWrite(led[i], LOW);
delay (0);
if(peak > 0 && peak <= N_PIXELS-1)
// colour peak dot
if(++dotCount >= PEAK_FALL) { //fall rate
if(peak > 0) peak--;
dotCount = 0;
vol[volCount] = n; // Save sample for dynamic leveling
if(++volCount >= SAMPLES) volCount = 0; // Advance/rollover sample counter
// Get volume range of prior frames
minLvl = maxLvl = vol[0];
for(i=1; i<SAMPLES; i++) {
if(vol[i] < minLvl) minLvl = vol[i];
else if(vol[i] > maxLvl) maxLvl = vol[i];
if((maxLvl - minLvl) < TOP) maxLvl = minLvl + TOP;
minLvlAvg = (minLvlAvg * 63 + minLvl) >> 6; // Dampen min/max levels
maxLvlAvg = (maxLvlAvg * 63 + maxLvl) >> 6; // (fake rolling average)
