Minor adjustment Need From Pro
Hello Everyone,
I'm new to arduino and learning stuff from this site,
and after watching some YT videos I made a VU meter and I need a few adjustments to the code
what I need to do is
I can define led number for only one strip, if I used second led strip how do I do that, I mean
First Strip with 40 LED and Second Strip with 20 LED
How Do I use Different numbers of LEDs to the two strips
I have Uploaded the codes and if anyone can do the changes it would be really grateful
I need to run the same effect with different LEDs on two strip
#include <FastLED.h>
#include <EEPROM.h>
#define PIN 6
#define N_PIXELS  34
#define BG 0
#define COLOR_ORDER GRB  // Try mixing up the letters (RGB, GBR, BRG, etc) for a whole new world of color combinations
#define BRIGHTNESS 255   // 0-255, higher number is brighter.
#define LED_TYPE WS2812B
#define MIC_PIN   A4  // Microphone is attached to this analog pin
#define DC_OFFSET  0  // DC offset in mic signal - if unusure, leave 0
#define NOISE     10  // Noise/hum/interference in mic signal
#define SAMPLES   60  // Length of buffer for dynamic level adjustment
#define TOP       (N_PIXELS + 2) // Allow dot to go slightly off scale
#define PEAK_FALL 20  // Rate of peak falling dot
#define N_PIXELS_HALF (N_PIXELS/2)
#define GRAVITY           -9.81              // Downward (negative) acceleration of gravity in m/s^2
#define h0                1                  // Starting height, in meters, of the ball (strip length)
#define NUM_BALLS         3                  // Number of bouncing balls you want (recommend < 7, but 20 is fun in its own way)
#define SPEED .20       // Amount to increment RGB color by each cycle
int brightnessPin = A0, potPin = A1;
//config for balls
float h[NUM_BALLS] ;                         // An array of heights
float vImpact0 = sqrt( -2 * GRAVITY * h0 );  // Impact velocity of the ball when it hits the ground if "dropped" from the top of the strip
float vImpact[NUM_BALLS] ;                   // As time goes on the impact velocity will change, so make an array to store those values
float tCycle[NUM_BALLS] ;                    // The time since the last time the ball struck the ground
int   pos[NUM_BALLS] ;                       // The integer position of the dot on the strip (LED index)
long  tLast[NUM_BALLS] ;                     // The clock time of the last ground strike
float COR[NUM_BALLS] ;                       // Coefficient of Restitution (bounce damping)
float
  greenOffset = 30,
  blueOffset = 150;
byte
  peak      = 0,      // Used for falling dot
  dotCount  = 0,      // Frame counter for delaying dot-falling speed
  volCount  = 0;      // Frame counter for storing past volume data
int
  vol[SAMPLES],       // Collection of prior volume samples
  lvl       = 10,      // Current "dampened" audio level
  minLvlAvg = 0,      // For dynamic adjustment of graph low & high
  maxLvlAvg = 512;
  int brightnessValue, prevBrightnessValue;
int sensorDeviationBrightness = 1;
int sensitivityValue = 128;                               // 0 - 255, initial value (value read from the potentiometer if useSensorValues = true)
int maxSensitivity = 2 * 255;                             // let the 'volume' go up to 200%!
int ledBrightness = 255;                                   // 0 - 255, initial value (value read from the potentiometer if useSensorValues = true)
int val;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_PIXELS, PIN, NEO_GRB + NEO_KHZ800);
// FOR SYLON ETC
uint8_t thisbeat =  23;
uint8_t thatbeat =  28;
uint8_t thisfade =   2;                                     // How quickly does it fade? Lower = slower fade rate.
uint8_t thissat = 255;                                     // The saturation, where 255 = brilliant colours.
uint8_t thisbri = 255;
//FOR JUGGLE
uint8_t numdots = 4;                                          // Number of dots in use.
uint8_t faderate = 2;                                         // How long should the trails be. Very low value = longer trails.
uint8_t hueinc = 16;                                          // Incremental change in hue between each dot.
uint8_t thishue = 0;                                          // Starting hue.
uint8_t curhue = 0;
uint8_t thisbright = 255;                                     // How bright should the LED/display be.
uint8_t basebeat = 5;
uint8_t max_bright = 255;
// Twinkle
float redStates[N_PIXELS];
float blueStates[N_PIXELS];
float greenStates[N_PIXELS];
float Fade = 0.96;
// Vu meter 4
const uint32_t Red = strip.Color(255, 0, 0);
const uint32_t Yellow = strip.Color(255, 255, 0);
const uint32_t Green = strip.Color(0, 255, 0);
const uint32_t Blue = strip.Color(0, 0, 255);
const uint32_t White = strip.Color(255, 255, 255);
const uint32_t Dark = strip.Color(0, 0, 0);
unsigned int sample;
CRGB leds[N_PIXELS];
int          myhue =   0;
// constants used here to set pin numbers:
const int buttonPin = 3;     // the number of the pushbutton pin
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;
//Ripple variables
int color;
int center = 0;
int step = -1;
int maxSteps = 8;
float fadeRate = 0.80;
int diff;
//background color
uint32_t currentBg = random(256);
uint32_t nextBg = currentBg;
  delay( 2000 ); // power-up safety delay
  FastLED.addLeds<WS2812B, PIN, COLOR_ORDER>(leds, N_PIXELS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(  BRIGHTNESS );
  analogReference(EXTERNAL);
  memset(vol, 0, sizeof(vol));
  LEDS.addLeds<LED_TYPE, PIN, COLOR_ORDER>(leds, N_PIXELS);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  //initialize the serial port
   pinMode(buttonPin, INPUT);
    pinMode(2, OUTPUT);
  //initialize the buttonPin as output
digitalWrite(buttonPin, HIGH);
digitalWrite(2, HIGH);
 for (int i = 0 ; i < NUM_BALLS ; i++) {    // Initialize variables
    tLast[i] = millis();
    h[i] = h0;
    pos[i] = 0;                              // Balls start on the ground
    vImpact[i] = vImpact0;                   // And "pop" up at vImpact0
    tCycle[i] = 0;
    COR[i] = 0.90 - float(i)/pow(NUM_BALLS,2);
   brightnessValue = analogRead(brightnessPin);
  brightnessValue = map(brightnessValue, 0, 1023, 0, 255);
  if (abs(brightnessValue - prevBrightnessValue) > sensorDeviationBrightness) {
    ledBrightness = brightnessValue;
    strip.setBrightness(ledBrightness);
    prevBrightnessValue = brightnessValue;
   //for mic
  uint8_t  i;
  uint16_t minLvl, maxLvl;
  int      n, height;
  // end mic
  buttonPushCounter=EEPROM.read(0);
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
    // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
      if(buttonPushCounter>=14) {
      buttonPushCounter=1;}
      EEPROM.write(0,buttonPushCounter);
    else {
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
switch (buttonPushCounter){
  case 1:
     buttonPushCounter==1; {
      vu(); // Red
     break;}
  case 2:
     buttonPushCounter==2; {
       vu2(); // Red
      break;}
   case 3:
     buttonPushCounter==3; {
    Vu3(); //
      break;}
    case 4:
     buttonPushCounter==4; {
    Vu4(); //
      break;}
       case 5:
     buttonPushCounter==5; {
      rainbow(150);
       break;}
        case 6:
     buttonPushCounter==6; {
      rainbow(20);
       break;}
         case 7:
     buttonPushCounter==7; {
      ripple();
       break;}
           case 8:
     buttonPushCounter==8; {
      ripple2();
       break;}
              case 9:
     buttonPushCounter==9; {
      Twinkle();
       break;}
         case 10:
     buttonPushCounter==10; {
      pattern2();
       break;}
           case 11:
     buttonPushCounter==11; {
      pattern3();
       break;}
           case 12:
     buttonPushCounter==12; {
    Balls(); //
      break;}
        case 13:
     buttonPushCounter==13; {
    colorWipe(strip.Color(0, 0, 0), 10); // A Black
      break;}
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      if (digitalRead(buttonPin) != lastButtonState)  // <------------- add this
       return;         // <------------ and this
      delay(wait);
void Vu4() {
    uint8_t  i;
  int      n, height;
  val = (analogRead(potPin));
  val= map(val, 0, 1023, -10, 6);
  n   = analogRead(MIC_PIN);                        // Raw reading from mic
  n   = abs(n - 0 - DC_OFFSET); // Center on zero
  n   = (n <= NOISE) ? 0 : (n - NOISE);             // Remove noise/hum
    if(val<0){
        n=n/(val*(-1));
       if(val>0){
        n=n*val;
  lvl = ((lvl * 7) + n) >> 3;    // "Dampened" reading (else looks twitchy)
  // Calculate bar height based on dynamic min/max levels (fixed point):
  height = TOP * (lvl - minLvlAvg) / (long)(maxLvlAvg - minLvlAvg);
  if(height < 0L)       height = 0;      // Clip output
  else if(height > TOP) height = TOP;
  if(height > peak)     peak   = height; // Keep 'peak' dot at top
  greenOffset += SPEED;
  blueOffset += SPEED;
  if (greenOffset >= 255) greenOffset = 0;
  if (blueOffset >= 255) blueOffset = 0;
  // Color pixels based on rainbow gradient
  for(i=0; i<N_PIXELS_HALF; i++) {
    if(i >= height) {
      strip.setPixelColor(N_PIXELS_HALF-i-1,   0,   0, 0);
      strip.setPixelColor(N_PIXELS_HALF+i,   0,   0, 0);
    else {
      uint32_t color = Wheel(map(i,0,N_PIXELS_HALF-1,(int)greenOffset, (int)blueOffset));
      strip.setPixelColor(N_PIXELS_HALF-i-1,color);
      strip.setPixelColor(N_PIXELS_HALF+i,color);
  // Draw peak dot
  if(peak > 0 && peak <= N_PIXELS_HALF-1) {
    uint32_t color = Wheel(map(peak,0,N_PIXELS_HALF-1,30,150));
    strip.setPixelColor(N_PIXELS_HALF-peak-1,color);
    strip.setPixelColor(N_PIXELS_HALF+peak,color);
   strip.show(); // Update strip
// Every few frames, make the peak pixel drop by 1:
    if(++dotCount >= PEAK_FALL) { //fall rate
      if(peak > 0) peak--;
      dotCount = 0;
  vol[volCount] = n;                      // Save sample for dynamic leveling
  if(++volCount >= SAMPLES) volCount = 0; // Advance/rollover sample counter
  // Get volume range of prior frames
  minLvl = maxLvl = vol[0];
  for(i=1; i<SAMPLES; i++) {
    if(vol[i] < minLvl)      minLvl = vol[i];
    else if(vol[i] > maxLvl) maxLvl = vol[i];
  // minLvl and maxLvl indicate the volume range over prior frames, used
  // for vertically scaling the output graph (so it looks interesting
  // regardless of volume level).  If they're too close together though
  // (e.g. at very low volume levels) the graph becomes super coarse
  // and 'jumpy'...so keep some minimum distance between them (this
  // also lets the graph go to zero when no sound is playing):
  if((maxLvl - minLvl) < TOP) maxLvl = minLvl + TOP;
  minLvlAvg = (minLvlAvg * 63 + minLvl) >> 6; // Dampen min/max levels
  maxLvlAvg = (maxLvlAvg * 63 + maxLvl) >> 6; // (fake rolling average)
void Vu3() {
  uint8_t i;
  int n, height;
      if(val<0){
        n=n/(val*(-1));
       if(val>0){
        n=n*val;
  if (height < 0L)       height = 0;      // Clip output
  else if (height > TOP) height = TOP;
  if (height > peak)     peak   = height; // Keep 'peak' dot at top
  for (i = 0; i < N_PIXELS; i++) {
    if (i >= height) {
      strip.setPixelColor(i, 0, 0, 0);
      strip.setPixelColor(i, Wheel(
        map(i, 0, strip.numPixels() - 1, (int)greenOffset, (int)blueOffset)
  // Draw peak dot
  if(peak > 0 && peak <= N_PIXELS-1) strip.setPixelColor(peak,Wheel(map(peak,0,strip.numPixels()-1,30,150)));
      dotCount = 0;
  vol[volCount] = n;
  if (++volCount >= SAMPLES) {
    volCount = 0;
  for (i = 1; i < SAMPLES; i++) {
    if (vol[i] < minLvl) {
      minLvl = vol[i];
    } else if (vol[i] > maxLvl) {
      maxLvl = vol[i];
  if ((maxLvl - minLvl) < TOP) {
void Balls() {
    tCycle[i] =  millis() - tLast[i] ;     // Calculate the time since the last time the ball was on the ground
    // A little kinematics equation calculates positon as a function of time, acceleration (gravity) and intial velocity
    h[i] = 0.5 * GRAVITY * pow( tCycle[i]/1000 , 2.0 ) + vImpact[i] * tCycle[i]/1000;
    if ( h[i] < 0 ) {
      h[i] = 0;                            // If the ball crossed the threshold of the "ground," put it back on the ground
      vImpact[i] = COR[i] * vImpact[i] ;   // and recalculate its new upward velocity as it's old velocity * COR
      if ( vImpact[i] < 0.01 ) vImpact[i] = vImpact0;  // If the ball is barely moving, "pop" it back up at vImpact0
    pos[i] = round( h[i] * (N_PIXELS - 1) / h0);       // Map "h" to a "pos" integer index position on the LED strip
  //Choose color of LEDs, then the "pos" LED on
  for (int i = 0 ; i < NUM_BALLS ; i++) leds[pos[i]] = CHSV( uint8_t (i * 40) , 255, 255);
  FastLED.show();
  //Then off for the next loop around
    leds[pos[i]] = CRGB::Black;
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
      delay(wait);
// HERE
void vu() {
  uint8_t  i;
  int      n, height;
     if(val<0){
        n=n/(val*(-1));
       if(val>0){
        n=n*val;
  for(i=0; i<N_PIXELS; i++) {
    if(i >= height)               strip.setPixelColor(i,   0,   0, 0);
    else strip.setPixelColor(i,Wheel(map(i,0,strip.numPixels()-1,30,150)));
  // Draw peak dot
      dotCount = 0;
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
void vu2() {
  uint8_t  i;
  int      n, height;
      if(val<0){
        n=n/(val*(-1));
       if(val>0){
        n=n*val;
    if(i >= height) {
    else {
      uint32_t color = Wheel(map(i,0,N_PIXELS_HALF-1,30,150));
  // Draw peak dot
      dotCount = 0;
//here................
 void ripple() {
    if (currentBg == nextBg) {
      nextBg = random(256);
    else if (nextBg > currentBg) {
      currentBg++;
      currentBg--;
    for(uint16_t l = 0; l < N_PIXELS; l++) {
      leds[l] = CHSV(currentBg, 255, 50);         // strip.setPixelColor(l, Wheel(currentBg, 0.1));
  if (step == -1) {
    center = random(N_PIXELS);
    color = random(256);
    step = 0;
  if (step == 0) {
    leds[center] = CHSV(color, 255, 255);         // strip.setPixelColor(center, Wheel(color, 1));
    step ++;
  else {
    if (step < maxSteps) {
      Serial.println(pow(fadeRate,step));
      leds[wrap(center + step)] = CHSV(color, 255, pow(fadeRate, step)*255);       //   strip.setPixelColor(wrap(center + step), Wheel(color, pow(fadeRate, step)));
      leds[wrap(center - step)] = CHSV(color, 255, pow(fadeRate, step)*255);       //   strip.setPixelColor(wrap(center - step), Wheel(color, pow(fadeRate, step)));
      if (step > 3) {
        leds[wrap(center + step - 3)] = CHSV(color, 255, pow(fadeRate, step - 2)*255);     //   strip.setPixelColor(wrap(center + step - 3), Wheel(color, pow(fadeRate, step - 2)));
        leds[wrap(center - step + 3)] = CHSV(color, 255, pow(fadeRate, step - 2)*255);     //   strip.setPixelColor(wrap(center - step + 3), Wheel(color, pow(fadeRate, step - 2)));
      step ++;
    else {
      step = -1;
  LEDS.show();
  delay(50);
int wrap(int step) {
  if(step < 0) return N_PIXELS + step;
  if(step > N_PIXELS - 1) return step - N_PIXELS;
  return step;
void one_color_allHSV(int ahue, int abright) {                // SET ALL LEDS TO ONE COLOR (HSV)
  for (int i = 0 ; i < N_PIXELS; i++ ) {
    leds[i] = CHSV(ahue, 255, abright);
void ripple2() {
  if (BG){
      currentBg++;
      currentBg--;
      strip.setPixelColor(l, 0, 0, 0);
  if (step == -1) {
    step = 0;
  if (step == 0) {
    step ++;
  else {
      if (step > 3) {
      step ++;
    else {
      step = -1;
  strip.show();
  delay(50);
//int wrap(int step) {
//  if(step < 0) return Pixels + step;
//  if(step > Pixels - 1) return step - Pixels;
//  return step;
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos, float opacity) {
  if(WheelPos < 85) {
    return strip.Color((WheelPos * 3) * opacity, (255 - WheelPos * 3) * opacity, 0);
    WheelPos -= 85;
    return strip.Color((255 - WheelPos * 3) * opacity, 0, (WheelPos * 3) * opacity);
  else {
    WheelPos -= 170;
    return strip.Color(0, (WheelPos * 3) * opacity, (255 - WheelPos * 3) * opacity);
   void pattern2() {
       sinelon();                                                  // Call our sequence.
  show_at_max_brightness_for_power();                         // Power managed display of LED's.
} // loop()
void sinelon() {
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, N_PIXELS, thisfade);
  int pos1 = beatsin16(thisbeat,0,N_PIXELS);
  int pos2 = beatsin16(thatbeat,0,N_PIXELS);
    leds[(pos1+pos2)/2] += CHSV( myhue++/64, thissat, thisbri);
// Pattern 3 - JUGGLE
    void pattern3() {
       ChangeMe();
  juggle();
} // loop()
void juggle() {                                               // Several colored dots, weaving in and out of sync with each other
  curhue = thishue;                                          // Reset the hue values.
  fadeToBlackBy(leds, N_PIXELS, faderate);
  for( int i = 0; i < numdots; i++) {
    leds[beatsin16(basebeat+i+numdots,0,N_PIXELS)] += CHSV(curhue, thissat, thisbright);   //beat16 is a FastLED 3.1 function
    curhue += hueinc;
} // juggle()
void ChangeMe() {                                             // A time (rather than loop) based demo sequencer. This gives us full control over the length of each sequence.
  uint8_t secondHand = (millis() / 1000) % 30;                // IMPORTANT!!! Change '30' to a different value to change duration of the loop.
  static uint8_t lastSecond = 99;                             // Static variable, means it's only defined once. This is our 'debounce' variable.
  if (lastSecond != secondHand) {                             // Debounce to make sure we're not repeating an assignment.
    lastSecond = secondHand;
    if (secondHand ==  0)  {numdots=1; faderate=2;}  // You can change values here, one at a time , or altogether.
    if (secondHand == 10)  {numdots=4; thishue=128; faderate=8;}
    if (secondHand == 20)  {hueinc=48; thishue=random8();}                               // Only gets called once, and not continuously for the next several seconds. Therefore, no rainbows.
} // ChangeMe()
void Twinkle () {
   if (random(25) == 1) {
      uint16_t i = random(N_PIXELS);
      if (redStates[i] < 1 && greenStates[i] < 1 && blueStates[i] < 1) {
        redStates[i] = random(256);
        greenStates[i] = random(256);
        blueStates[i] = random(256);
      if (redStates[l] > 1 || greenStates[l] > 1 || blueStates[l] > 1) {
        strip.setPixelColor(l, redStates[l], greenStates[l], blueStates[l]);
        if (redStates[l] > 1) {
          redStates[l] = redStates[l] * Fade;
          redStates[l] = 0;
        if (greenStates[l] > 1) {
          greenStates[l] = greenStates[l] * Fade;
          greenStates[l] = 0;
        if (blueStates[l] > 1) {
          blueStates[l] = blueStates[l] * Fade;
          blueStates[l] = 0;
    strip.show();
     delay(10);
// TOO HERE
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    // check if a button pressed
    delay(wait);
Processing: VU Meter.txt...
VU Meter.zip (6.9 KB)
People are generally unwilling to open zip files.
Please post your code here, in code tags (the </> symbol on the toolbar)
You could make another strip object like
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel( 20, TheOtherPinb, NEO_GRB + NEO_KHZ800);
When you instantiate the ‘strip’, you can create an array of strips, one with 40 pixels, and a second with 20.
From there on, you simply address the strips individually as needed e.g. strip[0]…and strip[1]…
I'm not a programmer :slightly_frowning_face: and can you made the changes for me then I will try,
I still learning from scratch :slightly_smiling_face:
Thanks for the reply
Why are you using both FastLED and Adafruit_NeoPixel?
This code from Youtube CINE Light i'm not the original owner of this code.
i mailed him and he didn't reply
I would start by using only one of these Addressable LED libraries. If you go with FastLED, they have a tutorial describing several different ways to support multiple LED strips: https://github.com/FastLED/FastLED/wiki/Multiple-Controller-Examples
Once you choose which library you’re going to use, look at reply #4, and see how you go with a simple test using an array of strips.
Once you understand, you can soon be the ‘author of this code’.
There’s no better time than now to start learning. As you move forward, ask more questions, we’ll be happy to help.
