I can't find a data sheet on those 10watt LEDs but...
10watt / 3 LED's (to give a share of each)
= 3.3watts per share (3 watts Red, Green, Blue).
3 watts at 12v
Roughly 0.25amps per RGB.
I'm well aware of the current limiter, the current is slightly too high for a UNL transistor array IC, too low for use of a mosfet, so to hell with it (I've got a 2n2222 for each segment 15 NPN's each heatsinked), I have in total 5 - 10watt LEDs, I decided to take a risk and not use any current limiting (Except on base), collector/emitter side and use a 1-5k resistor on the base to limit the current (eg, 2k for RED, 1k for Blue 800ohms for Green), which is all done, then I adjust the PWM to lower the current (for in the warmer months) and increase the current for colder months, i'll use an NTC thermistor or something as "reference" if it does not go to plan.
I'm not asking for help, just telling you what's going on...
What I can't decide on, these 10watt LEDs, there's 3 LED's in series (3 forward voltage drops), if each of these little LED's must be 1watt each, giving 3watts per channel., I have a 300watt heatsink along with all the transistors mounted on the heatsink along with the LEDs...
This may fail spectacularly after 30 minutes of 50watts of current draw lol... I have a large switching power supply raring to go... So here goes, one monster RGB LED chaser lol...
Either way i'll take pictures
When done, I'll have it soldered up and I'll stick it outside somewhere.. (the pink LED in the background is barely drawing 80ma it's a 1watt LED) this LED bar (when running at full power) should make you see pretty stars for a while after viewing it....
