Hi everyone
Im attempting to build a high voltage (1000V) electromagnet pulse driver using a 1200V rated IGBT with a gate driver and an arduino for switching.
I have attached datasheets for the IGBT and the driver.
I have attached a schematic as well. It simulates fine, but obviously iv screwed up somewhere.
I simulated at 48V, 600V and 1000V using isis. According to the simulation the electromagnet draws 20A at 600V, well within the datasheets specs.
The resistance of the electromagnet is 30 Ohms.
I initially tested the setup with 48V DC from a Meanwell power supply to drive the electromagnets and a 12V battery to power the transistor gate driver.
All worked flawlessly! Opening and closing the gate of the IGBT ![]()
I then substituted the 48V supply for a voltage multiplier and powered that with 220V AC, giving me 600V DC.
I powered up the driver, then the arduino, then the multiplier. Just as I had done before with the 48V supply.
This time it energised the electromagnet and it stayed energised. The 2 electromagnets are not meant to be driven for more than 10-50ms.
So they overheated and started to melt their bobbins.
I powered everything down quick quick! Then tried again, the transistor no longer switched, and was permanently on.
I felt the driver and it was too hot, the IGBT however was not hot at all.
I checked the resistance of the IGBTs emitter to gate and I get a dead short. Obviously I murdered that poor transistor.
I have to admit, Iv never been too good with high voltage stuff, I like my 5V logic signals! ![]()
Where did I screw up and why? Did I miss something obvious? Was it the back EMF from the coils? My lack of intelligence or my bad luck? ![]()
Go easy on me ![]()
Thanks in advance!
Gareth
PS. While typing out this post I think i figured out where I screwed up. In simulation I used a single 30 Ohm solenoid, it drew 20A at 600V.
In testing I used two 30 Ohm electromagnets, which obviously drew 40A, which is above the rated current for the transistor.
Am I correct?
IRG4PH40KD.pdf (347 KB)
TC4426-TC4427-TC4428 1.5A Dual High-Speed Power MOSFET Drivers.pdf (431 KB)
