10's Unit Electrodes
Has anyone tried to make self-adhering fabric electrodes? Or has tried to mimic the prescribed device BodyMed Transcutaneous electrical nerve stimulator?
http://tensunitelectrodes.com/
By reading the description of the stimulator I guess... the pads are made from 'conductive foam'.
Looking at the prices of the stimulators, I also guess... they're relative simple devices. It may... be possible to build one yourself.
I'd be very cautious though.
If you use an arduino to blink a led without proper knowledge of electronics the chance of ruining the led is high.
If you want to treat pain without being a specialized doctor... the risk your patient may suffer more as before the experiment is high as well.
There is little harm in experimenting with most sensors (blood pressure, heart-rate, eeg, etc), but treatment is a completely different topic.
I'd agree with you on that. However the shock couldn't be too serious with this 9v device. Even apply the pad to a block of wood and simply touch to feel the effect.
Buy your own pads as they are reusable over 100 times ( I use them ).
The voltage is stepped up to about 80 volts from 9 Volts and then pulsed at different rates and pulse widths into the electrodes.
Hi, I agree with LarryD, I have a tens unit and the pads that come with it and are available can be used many times, and are washable.
This is the style I have, even my chemist has them.
Tom..... :slight_smile:
