Good design rules would seem to dictate that I should stick a couple bypass capacitors on my servo power pins. But I am unsure what value to use.
I know one should be a .1uf, but one post by Grumpymikle says 10uf for the other one, and I think at another point a 47uf may have been suggested. Grumpy's tutorials also show 47uf across noisy motors.
So is 10uf sufficient, or should I go larger?
And are a couple cpaacitors sufficent for both servos, or should I have a pair per servo? The power connectors on my board will be right next to one another so the capacitors wouldn't be far from either one.
