Illuminated switches have three connections, input, ground and output. The bulb/LED is between output and
ground. I presume you've just not shown the ground connections on that diagram as Fritzing has no symbol?
I think you mean 1.4k and 1k. Use 1.5k and 1k as 1.5k is a more common value. You need one resistor
divider for every switch since each switch is a separate signal.
Another way to do this is use a resistor/zener divider, say 10k+4V7, or just use a >= 10k resistor and let the
input protection diode carry the current (not as robust though).
Thanks for the feedback, you're right about the resistors, dropped a zero along the way. Putting a 1.5k resistor would drop the voltage to 4.8 volts, is that enough to read high on the Arduino pins?
Also, have I got the wires in the correct place, in between the resistors?
Also, this is going to be built into a wooden structure in my kids room, do I need to worry about heat dropping the voltage so much?
With regards to ground connections, I reworked the diagram with the correct wiring, does that make more sense?
That diagram has those switches shorting the 12V supply to gnd when in the left position, don't use fritzy, I understand that they are not the switches that you are really using.
What switches are you using?
Please post a link to spec/data of the switches.
Can you post a picture of your switch please?
maxmon:
3.0V reads HIGH, < 1.5V reads LOW, guaranteed for 5V operation of ATmega chips (see datasheet electrical
characteristics).
Note this means that 3.3V logic signals can just be read by a 5V Arduino reliably...
