12V LED strips w/ Nano - power pulse/flickering issue
Hello,
I have an issue with my arduino nano beginning to pulse after a few seconds after triggering my 4 pwm outputs at full power (255). The pwm signals are going through TIP120's to regulate the current flow to ground for a 12V led strip. I have one strip with R, G, and B connected to pins 9, 10, and 11. I have the other attached to 6, and have the RGB pins on that strip all bridged together (illuminates white). My issue, is when I power them up, the lights stay on with the 12v supply to Vin/Gnd but then after a few seconds they begin to reset/pulse. I then plug in the usb connection to my computer and the issue goes away. My supply is a 12v 5A constant voltage supply. I tried adding 0.1 uF and 4.7uF capacitor across Vin/Gnd but that didn't help it. If I back down the pwm output to 200, then the issue takes much longer to occur (20ish seconds). once the issue starts, I can stop the flashing by plugging in the USB connection, but as soon as I unplug it begins again.
Any thoughts as to my issue? Thank you!
I monitored current during the flashing and it is dropping from 1.1A during normal operation all the way down to .5A during a flash. what could be causing this flashing to appear after 20-30 seconds?
Need:
  • your code
  • your circuit schematic
#include <stdio.h>
#include <stdlib.h>
#define white 6
#define red 9
#define blue 10
#define green 11
int brightness = 200;
  pinMode(red, OUTPUT);
  pinMode(blue, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(white, OUTPUT);
  analogWrite(red, brightness);
  analogWrite(green, brightness);
  analogWrite(blue, brightness);
  analogWrite(white, brightness);
this in a nutshell granted I'm using pins 6, 9, 10, and 11.
Take another look in that nutshell, perhaps the base resistors are hiding in there.
good golly you were right! it was pulling too much power without resistors and was heating up the main chip really bad! I added 1.5k resistors between the base and pwm pins and that solved my flickering issue. thank you so so much!
So what was critically missing was the explanation in the OP that he was using some unspecified transistors - presumably rubbish TIP121s - instead of modern FETs! :astonished:
