#include <WiFiNINA.h>
WiFiNINA wifiNina;
error: 'WiFiNINA' does not name a type; did you mean 'WiFiNINA_h'?
WiFiNINA wifiNina;
Bard.Google.com has had me delete and reinstall WiFiNINA, check to be sure WiFiNINA was in the libraries folder (it wasn't, now it is), restart Arduino (2.2.1), and reboot the computer. I'm still getting the error above. Bard says the copy of WiFiNINA from Github might have something wrong with it. It also says I should contact this forum.
You do not need to create a object with this library so the second line is not necessary and is what is causing your issue.
As demonstrated in this example sketch:
This example connects to an encrypted WiFi network (WPA/WPA2).
Then it prints the MAC address of the board,
the IP address obtained, and other network details.
Then it continuously pings given host specified by IP Address or name.
Circuit:
* Board with NINA module (Arduino MKR WiFi 1010, MKR VIDOR 4000 and Uno WiFi Rev.2)
created 13 July 2010
by dlf (Metodo2 srl)
modified 09 June 2016
by Petar Georgiev
#include <SPI.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
// Specify IP address or hostname
String hostName = "www.google.com";
int pingResult;
// Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(5000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
printCurrentNet();
printWiFiData();
Serial.print("Pinging ");
Serial.print(hostName);
Serial.print(": ");
pingResult = WiFi.ping(hostName);
if (pingResult >= 0) {
Serial.print("SUCCESS! RTT = ");
Serial.print(pingResult);
Serial.println(" ms");
Serial.print("FAILED! Error code: ");
Serial.println(pingResult);
delay(5000);
void printWiFiData() {
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP address : ");
Serial.println(ip);
Serial.print("Subnet mask: ");
Serial.println((IPAddress)WiFi.subnetMask());
Serial.print("Gateway IP : ");
Serial.println((IPAddress)WiFi.gatewayIP());
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI): ");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type: ");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
