2.4 inch LCD TFT Display Shield only shows white!
I recently got a new LCD TFT Display Shield and when I try anything it only shows white! I can use the touchscreen library with no problems and can get coordinates but i can't show anything on the display! I just tried with the ADAFRUIT library and another one called TFTLCD. :cry: :frowning:
Can someone help me?? It shows C0C0 as my driver chip and says it it unknown!
I hoped to use this but it won't work either:
#include "TFTLCD.h"
#include "TouchScreen.h"
//Duemilanove/Diecimila/UNO/etc ('168 and '328 chips) microcontoller:
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET A4
// Color definitions
#define	BLACK           0x0000
#define	BLUE            0x001F
#define	RED             0xF800
#define	GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
  Serial.println("Paint!");
  tft.reset();
  uint16_t identifier = tft.readRegister(0x0);
  if (identifier == 0x9325) {
    Serial.println("Found ILI9325");
  } else if (identifier == 0x9328) {
    Serial.println("Found ILI9328");
    Serial.print("Unknown driver chip ");
    Serial.println(identifier, HEX);
    while (1);
  tft.initDisplay();
  tft.fillScreen(BLACK);
  tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
  tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
  tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
  tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
  tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
  tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
 // tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, WHITE);
 tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
 currentcolor = RED;
  pinMode(13, OUTPUT);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
  digitalWrite(13, HIGH);
  TSPoint p = ts.getPoint();
  digitalWrite(13, LOW);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //pinMode(YM, OUTPUT);
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    if (p.y < (TS_MINY-5)) {
      Serial.println("erase");
     // press the bottom of the screen to erase
      tft.fillRect(0, BOXSIZE, tft.width(), tft.height()-BOXSIZE, BLACK);
    // turn from 0->1023 to tft.width
    p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
    p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
    if (p.y < BOXSIZE) {
       oldcolor = currentcolor;
       if (p.x < BOXSIZE) {
         currentcolor = RED;
       else if (p.x < BOXSIZE*2) {
         currentcolor = YELLOW;
         tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*3) {
         currentcolor = GREEN;
         tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*4) {
         currentcolor = CYAN;
         tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*5) {
         currentcolor = BLUE;
         tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*6) {
         currentcolor = MAGENTA;
         tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, WHITE);
       if (oldcolor != currentcolor) {
          if (oldcolor == RED) tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
          if (oldcolor == YELLOW) tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
          if (oldcolor == GREEN) tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
          if (oldcolor == CYAN) tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
          if (oldcolor == BLUE) tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
          if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
    if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
      tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
Where did you buy the display? Do you have a link to it or any picture? I think you don't have the right library.
I don't have a picture or link, but it's one that says http://www.mcufriend.com on the back. I've tried going to that webpage, but it was taken down or something. I've tried to find others with the problem but everyone who gets it to work has a different solution and I can't get them to work. I think it may be the wrong pins but as it is a shield, I cannot change them physically. :slightly_frowning_face:
I'll post a picture as soon as I can get one.
I also recently got a similar 2.8 inch lcd display and got only a white screen.
I spent quite a while trying several "libraries" out with no success. Just a white screen.
I finally settled in on using the AdaFruit AdaTFTLCD library. I started putting serial print statements within the readID method and the problem went away. The sample code I'm using looks like this (within setup)
tft.reset();
uint16_t identifier = tft.readID();
By putting a delay (serial.print statement) into readID , I think I was allowing the reset operation to complete! I have not looked at the specs for the chipset which drives the display BUT it is often the case that a hardware reset takes a lot of time. In the end I put a delay(500) inside of the tft.reset method. I now read the device id successfully and have everything working.
You could also put the delay into the arduino setup code like this
tft.reset();
goltermc:
tft.reset();
I tried that, but it just said
Unknown driver chip 0
instead of
Unknown driver chip C0C0
Edit: It says C0C0 if I use the adafruit library.
:slightly_frowning_face: :slightly_frowning_face:
The display is still white too. :slightly_smiling_face:
Try this
I've attached my modified AdaTFTLCD arduino library as a zip file.
Unzip this in your arduino libraries directory (There is probably already an AdaTFTLCD directory there rename it before you unzip the one I am providing)
Restart the arduino IDE (or it will not be using the new library)
Open File->Examples->AdaTFT->graphicstest build that and see if it works.
Let me know how it goes
AdaTFTLCD.zip (153 KB)
I did it and the serial monitor says :
TFT LCD test
Using Adafruit 2.8" TFT Arduino Shield Pinout
TFT size is 240x320
Unknown LCD driver chip: C0C0
If using the Adafruit 2.8" TFT Arduino shield, the line:
  #define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
I also got the same when I added delay(500); after the reset function and before the driver detection.
I've put the current code on http://code.jazinc.cu.cc/codecollab/text/#tft-code
Hmmm..
C0C0 was what I got before I put the delay in the code.
One more thing to try.
Change this code
if(identifier == 0x9325) {
Serial.println(F("Found ILI9325 LCD driver"));
} else if(identifier == 0x9328) {
Serial.println(F("Found ILI9328 LCD driver"));
} else if(identifier == 0x7575) {
Serial.println(F("Found HX8347G LCD driver"));
} else if(identifier == 0x9341) {
Serial.println(F("Found ILI9341 LCD driver"));
} else if(identifier == 0x8357) {
Serial.println(F("Found HX8357D LCD driver"));
Serial.print(F("Unknown LCD driver chip: "));
Serial.println(F("If using the Adafruit 2.8" TFT Arduino shield, the line:"));
Serial.println(F(" #define USE_ADAFRUIT_SHIELD_PINOUT"));
Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
Serial.println(F("If using the breakout board, it should NOT be #defined!"));
Serial.println(F("Also if using the breakout, double-check that all wiring"));
Serial.println(F("matches the tutorial."));
return;
to this
//return;
identifier = 0x9341;
If that doesn't work change the identifier to each of the possibilities , one at a time and see if one of them works.
This in serial and still a white screen! :slightly_frowning_face: BTW: Thanks for all this help!
TFT LCD test
TFT size is 240x320
Benchmark                Time (microseconds)
Screen fill              450128
Text                     297976
Lines                    2970048
Horiz/Vert Lines         63876
Rectangles (outline)     51568
Rectangles (filled)      1263664
Circles (filled)         854356
Circles (outline)        1294216
Triangles (outline)      943164
Triangles (filled)       871560
Rounded rects (outline)  421340
Rounded rects (filled)   1591216
Done!
I tried all of it and changed delays, but it still will not work! Help!!! :slightly_frowning_face: :slightly_frowning_face:
Hi andersmmg,
I do not think you are using the library I provided. If you were your serial monitor would read
Using Adafruit 2.8" TFT Breakout Board Pinout
The message you are getting is
This indicates you are using an unmodified Adafruit_TFTLCD.h.
The pinout of the "made in china" TFTLCD shields is apparently different than the pinout used by a real AdaFruit Module.
In libraries/AdaTFTLCD/Adafruit_TFTLCD.h the line
#define USE_ADAFRUIT_SHIELD_PINOUT 1
must be commented out. Without this I believe the adafruit library will ignore the pinout the example is providing.
The Adafruit_TFTLCD.h which I provided has this line commented out.
The change I made to Adafruit_TFTLCD.cpp is very simple.
Open libraries/AdaTFTLCD/Adafruit_TFTLCD.cpp in an editor and search for Adafruit_TFTLCD::reset(void).
This is the reset method. It should look something like this.
void Adafruit_TFTLCD::reset(void) {
CS_IDLE;
// CD_DATA;
WR_IDLE;
RD_IDLE;
#ifdef USE_ADAFRUIT_SHIELD_PINOUT
digitalWrite(5, LOW);
delay(2);
digitalWrite(5, HIGH);
#else
// if we have a reset pin defined ( _reset )
if(_reset) {
digitalWrite(_reset, LOW);
delay(2);
digitalWrite(_reset, HIGH);
#endif
// Data transfer sync
CS_ACTIVE;
CD_COMMAND;
write8(0x00);
for(uint8_t i=0; i<3; i++) WR_STROBE; // Three extra 0x00s
CS_IDLE;
// let the display recover from the reset
The last two lines are what I added. If they are not there then add them. If they are there add
Serial.println("Added delay to the reset method");
Save the file and rebuild the test and rerun it. If you do not see
in the serial monitor, this library is not being used.
It is using that library and I triple checked that it is commented out and not defined, but I still get
!!!!!!!!! :slightly_frowning_face: :confused:
Serial.println(F("Using Adafruit 2.8" TFT Arduino Shield Pinout"));
#else
Serial.println(F("Using Adafruit 2.8" TFT Breakout Board Pinout"));
#endif
Is that how it's supposed to be?
It would appear that your adruino installation is getting the Adafruit_TFTLCD library from elsewhere.
So lets try a different approach.
I'm attaching a zipped adruino project which has all the Adafruit_TFTLCD library files renamed and local to the project.
Unzip this and it will create a directory called AndersmmgLcd. This should be placed in the same directory as your other Adruino projects.
Restart Arduino. Under File->Sketch you should see
AndersmmgLcd
Open this , build it and upload to your board.
Oops forgot to attach the zip
AndersmmgLcd.zip (19.5 KB)
OK, now I get a white screen and this in serial:
TFT LCD test
TFT size is 240x320
Unknown LCD driver chip: 4040
I noticed that is said my driver was 4040.
I have the same issue. The shield I'm using looks like this:
http://www.mcufriend.com/pic/unolcd/28-2.jpg
The screen just stays white and the ID returned is C0C0.
The touchscreen does work apparently, because I got values from it with one of the demo's and touching the srceen.
I've seen customer support from Adafruit say that the C0C0 ID indicates a dataline problem:
http://forums.adafruit.com/viewtopic.php?f=47&t=32807&p=162517&hilit=C0C0#p1
So I decided to measure all the pin connections with a multi meter and indeed one connection was bad. Fixed a wire over the break and immediately everything worked.
Now the example AdaFruit app states it has an ILI9341 LCD Driver.
goltermc:
Try this
Thank you! I almost gave up on this chinese 2.4tft that came without any library or documentation, but this worked like a charm, finally! :slight_smile:
The graphicstest example works perfectly. But what is the simplest sketch I can make to just print a plain old "Hello world" on the display? I've been deleting lots of code from graphicstest but I always get a compile code. I just want a real basic hello world, then start expanding on that...could anyone help?? I'm completely noob btw.
Hi!!
I too had purchased the similar LCD from this website
And i am using the Adafruit library, everything works fine, but the color on my LCD is blue.
Every color whether white, red, magenta everything looks blue.
Please suggest what i can do in this case.
I am attaching the images.
