2.4 inch tft
Hi!
can any one please tell me detail about this???
http://www.ebay.com/itm/2-4-inch-TFT-LCD-Module-Screen-240-x-320-Pixels-ILI9325-Arduino-Compatible-/141197618099?pt=LH_DefaultDomain_0&hash=item20e008abb3
this is 2.4" tft, which model use with it, i am using ILI9320 but its not working.
lib: UTFT
Board: Arduino MEGA or Due
TFT: SY-TFT240 (similar to HY-TFT240), 2.4" (320x240)
Driver: ILI9325C
Wiring:
TFT        MEGA or Due
GND        GND
5V          5V (3.3V internal regulator on TFT)
RS          38
RW          39
RD          3.3V
DB10        22
DB11        23
DB12        24
DB13        25
DB14        26
DB15        27
DB16        28
DB17        29
CS          40
RST         41
UTFT setting: UTFT myGLCD(3,38,39,40,41)
Arduino IDE: 1.5.8 BETA
Test on SD card reader
TFT       Due
CSI       Any free digital pin
MOSI      MOSI (header SPI)
SCK       SCK (header SPI)
MISO      MISO (header SPI)
lib: UTFT_tinyFAT for Arduino Due (TXH Graham)
Video image test
Thank you!!!
Hi, i have a similar display. I made some tests with it first and thought, it works fine.But now i have strange behaviors:
My setting: Arduino Mega2560. Henning Carlsens UTFT Library, connected with the following sheme:
myGLCD(A5,A4,A3,A2);
The problem comes with the Voltage: I have several pieces of the TFT, some of them work, when i connect the "RD"-pin to 3.3V of the Mega, some work without that connection. Some work, if connected 5V->5V and GND to GND, some when either GND or 5V is left out.
And one more strange thing: It works much more stable, when my Mega is powered only via USB. If i us an external power supply, the display resets very often (sometimes every second!), or simply doesn't work or shows just black and white stripes.
I measured the Voltage on the 5V-pin of my Mega. When it is connected via USB, it only has 4.5V, when externally powered, it has 4.95V. But i think both should be ok??
On the TFT i recognized a small IC with "662K" on it (it is labelled "U1"). I googled this, and it should be a Voltage regulator. So i am quite sure, the 5V-Logic Voltage of the Arduino Mega should be ok with this Display? I also tried to connect the Jumper "JP1" near this "U1"-IC, but then the TFT only shows a light blue screen.
So, summing up i can say that different items from the same type show slightly different behaviors, but all seems to be related to the voltage. Does anybody have any suggestions for me?
Hi! Im trying to get this to work with an Arduino Nano but I only get the screen to turn white and flicker. Is the Nano even compatible with this screen?
Hello
have a DUE and this Display
dont work with this. Why??????
TFT MEGA or Due
GND GND
RS 38
RW 39
RD 3.3V
DB10 22
DB11 23
DB12 24
DB13 25
DB14 26
DB15 27
DB16 28
DB17 29
CS 40
RST 41
Hi
I have a similar problem as Hahi....did you find a solution?
Br.
