2.8 TFT not working with Arduino UNO
I am trying to implement a Tic Tac Toe game that records gametime for each game on SD card using 2.8 TFT and UNO. My code is attached.
I am using this display board.
All i am getting is a white screen. Please help
new_code.ino (13.4 KB)
The second best feature of the Arduino IDE is . It makes your code readable by human people.
    p = ts.getPoint();  //Get touch point
    if (gameScreen == 3)
        buttonEnabled = true;
    if (p.z > ts.pressureThreshhold) {
        p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
        p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
        Serial.print("X = "); Serial.print(p.x);
        Serial.print("\tY = "); Serial.print(p.y);
        Serial.print("\n");
        if (p.x > 60 && p.x < 260 && p.y > 180 && p.y < 220 && buttonEnabled) // The user has pressed inside the red rectangle
            buttonEnabled = false; //Disable button
            Serial.println("Button Pressed")    ;
            resetGame();
            //This is important, because the libraries are sharing pins
            pinMode(XM, OUTPUT);
            pinMode(YP, OUTPUT);
            drawGameScreen();
            playGame();
        delay(10);
You can see that the pinMode() calls are not taken after every ts.getPoint()
If the Red triangle is not pressed, that block is never entered.
I suggest that you study examples. It is wise to put the pinMode() immediately after the getPoint(). Then it is never missed.
David.
Thank you for both CTRL + T and for suggesting about pinMode(). I will look into it.
