Does anyone know if -and how- I can connect 1 sensor (IR range finder) to 2 separate Arduino boards at the same time?
If I just connect the 3 (2 Arduino/1 Sensor) 5V Pins together, the 3 (2 Arduino/1 Sensor) Ground Pins together & the 3 (2 Arduino/1 Sensor) AnalogRead Pins together will it work?
(Or is there a chance I might destroy the boards...?)
Or maybe connect all 3 IR Sensor Pins to 1 Arduino Board and just the AnalogRead Sensor Pin to both?
Thank you,
Sofia
They shouldn't interact. The analog input does not disturb (much) the signal being connected to it. Just to be safe you may want to add 1k series resistors just before each analog input pin on each Arduino.
