2 arduinos communicating over CAN (sparkfun boards)
I have two arduino unos, both with sparkfun CAN shields. I've been trying for quite some time to get them to communicate however nothing seems to be working.
below is the sketch for receive
This is for use with Sparkfun's CAN Bus Shield: https://www.sparkfun.com/products/10039
#include <Canbus.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
  Serial.begin(9600); // For debug use
  Serial.println("CAN Read - Testing receive of CAN Bus message");
  if(Canbus.init(CANSPEED_500))  //Initialise MCP2515 CAN controller at the specified speed
    Serial.println("CAN Init ok");
    Serial.println("Can't init CAN");
void loop(){
  tCAN message;
if (mcp2515_check_message())
    if (mcp2515_get_message(&message))
        //if(message.id == 0x620 and message.data[2] == 0xFF)  //uncomment when you want to filter
               Serial.print("ID: ");
               Serial.print(message.id,HEX);
               Serial.print(", ");
               Serial.print("Data: ");
               Serial.print(message.header.length,DEC);
               for(int i=0;i<message.header.length;i++)
                  Serial.print(message.data[i],HEX);
                  Serial.print(" ");
               Serial.println("");
here is the sketch for send
#include <Canbus.h>
#include <global.h>
  Serial.println("CAN Write - Testing transmission of CAN Bus messages");
tCAN message;
        message.id = 0x631; //formatted in HEX
        message.header.rtr = 0;
        message.header.length = 8; //formatted in DEC
        message.data[0] = 0x40;
	message.data[1] = 0x05;
	message.data[2] = 0x30;
	message.data[3] = 0xFF; //formatted in HEX
	message.data[4] = 0x00;
	message.data[5] = 0x40;
	message.data[6] = 0x00;
	message.data[7] = 0x00;
mcp2515_bit_modify(CANCTRL, (1<<REQOP2)|(1<<REQOP1)|(1<<REQOP0), 0);
mcp2515_send_message(&message);
Runnning both sketches on different boards from my laptop,
CANH and CANL from both boards are connected to the bus with termination resistor of 120 ohm at either end on a bread board. the ground from each board is connected together also.
When both sketches run, the boards CAN INIT is successful, however i see no data being sent along the bus what so ever.
I'm extremely confused and don't understand where the problem is.
Any help would be greatly appreciated.
