That is a fairly specific part. If you are desperate you can get the opto isolator as a separate item from Sparkfun SparkFun Opto-isolator Breakout - BOB-09118 - SparkFun Electronics. That would drive the relay board you linked to. As far as two on one I do not know of any,
Please do not say it is for reversing a motor! To reverse a motor, you use a common 2 channel relay board with SPDT relays, not a DPDT relay which for the same size, generally has less durable contacts.
I do model train in DCC
I need to switch the signal which is 2 wires
I could do 4 SPDT (I thought about it) but if 1 relay fails, I may mix signals and not sure it's good for the DCC central or decoders in the locomotives....
Want to do this....
I have an arduino Nanon laying around, and will need it for an auto-reverse module
So I thought I would use it as well to drive relay, depending on the state of 1 switch ("Main" or "Prog")
french_guy:
Just wire 1 jumper from the output to both input, that's it?
Yes, basically. Just check the spec on your relay board to ensure that the current required for the two optoisolators doesn't exceed the pin limit on your Arduino (40mA).
wildbill:
Make that 20 mA (40 mA is the absolute max and not to be used as design spec).
french_guy:
it's digital signal.....
The 74HC125 or 74HC126 can easily switch digital signals.
