2 "independent" flickering diodes
Hey everyone!
I'm new to arduino and this is my first try... :grinning:
I'd like to simulate some faulty lamp flickering. I'm using leds for now but eventually will use mosfets switch 12v led lamps on and off.
my first try was using just one diode worked fine
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
// the loop function runs over and over again forever
  int wait1 = random(1,15);
  for (int j = 0; j <= wait1; j++){
    delay (1000);
  flickering(13);
int flickering(int x){
  int flick = random(3,15);
  for (int i = 0; i <= flick; i++) {
    digitalWrite(x, LOW);
    delay(random(10,100));
    digitalWrite(x, HIGH);
but now I'm trying to control two leds independently, I wasn't able to come up with something using a for loop so I've try this
  pinMode(12, OUTPUT);
  digitalWrite(12, HIGH);
  int wait1 = 20;
  int wait2 = 20;
  int j = 0;
  int m = 0;
  while (true){
    if (j = wait1){
    flickering(13);
    j = 0;
    if (m = wait2){
    flickering(12);
    m = 0;
  delay (1000);
  j = j+1;
  m = m+1;
Eventhough the leds blink independently they never stay on for 20 seconds... what am I missing?
Thank you
To control two leds independently you can't use delay() in your code. Open and read the "Blink without delay" IDE example - it exactly what you need.
You mean “j == wait1”. Similar for wait2.
consider
struct Lamp {
    const byte  pin;
    unsigned long msecLst;
    unsigned long msecPeriod;
lamps [] = {
    { 10 },
    { 11 },
    { 12 },
    { 13 },
#define Nlamps  (sizeof(lamps)/sizeof(Lamp))
void loop ()
    unsigned long msec = millis ();
    Lamp *p = lamps;
    for (unsigned n = 0; n < Nlamps; n++, p++)  {
        if ((msec - p->msecLst) >= p->msecPeriod)  {
            p->msecLst    = msec;
            p->msecPeriod = random (10, 100);
            digitalWrite (p->pin, ! digitalRead (p->pin));
void setup () {
    for (unsigned n = 0; n < Nlamps; n++)  {
        pinMode (lamps [n].pin, OUTPUT);
Here is a simple C++ class example I wrote a couple of years ago. You would need to modify it a bit for different on and off times. It allows multiple blinking objects.
 * Blink
 * Blink using a c++ class to toggle pin
 * Each time the toggle member function is called a
 *  check is done to see if it is time to toggle yet
// Interface description - this must be first and would
//  normally be in a header file as part of a library
class TogglePin {
  public:
    // constructors:
    TogglePin(byte inPinNumber);
    TogglePin(byte inPinNumber, unsigned long inDelayTime);
    // delay setter method:
    void setDelay(unsigned long inDelayTime);
    // doit method:
    void toggle(void);
   private:
    // minimize chances for user to screw up
     TogglePin (const  TogglePin& a);              // disallow copy constructor
     TogglePin & operator=(const  TogglePin& a);   // disallow assignment operator
    // object data
    byte pinState;            // current pin state
    byte pinNumber;           // pin to use
    unsigned long delayTime;  // delay in ms
    unsigned long currentMs;  // current ms count
    unsigned long testMs;     // test ms
};   // end TogglePin class definition
// Implementation - this would normally be in a .cpp
//   file as part of a library
TogglePin::TogglePin(byte inPinNumber)
  pinMode(inPinNumber, OUTPUT);   // sets the digital pin as output
  pinState=HIGH;
  pinNumber=inPinNumber;
  delayTime=1000;
  testMs=millis();
TogglePin::TogglePin(byte inPinNumber, unsigned long inDelayTime)
  pinState=HIGH;
  delayTime=inDelayTime;
  testMs=millis();
void TogglePin::setDelay(unsigned long inDelayTime)
void TogglePin::toggle(void)
  currentMs=millis();
  if((currentMs-testMs)>=delayTime) {
    //delay is up
    pinState^=1;                      //toggle state
    digitalWrite(pinNumber,pinState); // write new pin value
    testMs=currentMs;
/* ********************* Start Demo Code **/
byte blinkPin1 = 12;     // LED connected to digital pin 12
byte blinkPin2 = 13;     // LED connected to digital pin 13 - onboard LED
TogglePin blink1(blinkPin1);            // default constructor 1 sec delay
TogglePin blink2(blinkPin2,300);        // constructor with 300 ms delay
    // Move along - nothing to see here
void loop()                     // run over and over again
  blink1.toggle();
  blink2.toggle();
  // other interesting code here
  // it should take much less than the blink time, otherwise the
  // blink time will be dependent on the code execution time
/* ********************* End Demo Code **/
Thanks everyone I've by modfing the non delay blinking example! :wink:
I've another question a bit OT but related to my project.
I'm using this kind of led driver to power up my led lamps.
Can I use it's 12V output to power arduino uno too?
Sure you can
Thanks, would it be better to filter it and/or reduce it a bit?
