I know what the program is doing a loop, the rest is the sensor’s settings, I do not understand.
If arduino connected to the computer, and the computer has internet so arduino connected to the Internet?
#include <Wire.h>
#define MPU9150_SELF_TEST_X 0x0D // R/W
#define MPU9150_SELF_TEST_Y 0x0E // R/W
#define MPU9150_SELF_TEST_X 0x0F // R/W
#define MPU9150_SELF_TEST_A 0x10 // R/W
#define MPU9150_SMPLRT_DIV 0x19 // R/W
#define MPU9150_CONFIG 0x1A // R/W
#define MPU9150_GYRO_CONFIG 0x1B // R/W
#define MPU9150_ACCEL_CONFIG 0x1C // R/W
#define MPU9150_FF_THR 0x1D // R/W
#define MPU9150_FF_DUR 0x1E // R/W
#define MPU9150_MOT_THR 0x1F // R/W
#define MPU9150_MOT_DUR 0x20 // R/W
#define MPU9150_ZRMOT_THR 0x21 // R/W
#define MPU9150_ZRMOT_DUR 0x22 // R/W
#define MPU9150_FIFO_EN 0x23 // R/W
#define MPU9150_I2C_MST_CTRL 0x24 // R/W
#define MPU9150_I2C_SLV0_ADDR 0x25 // R/W
#define MPU9150_I2C_SLV0_REG 0x26 // R/W
#define MPU9150_I2C_SLV0_CTRL 0x27 // R/W
#define MPU9150_I2C_SLV1_ADDR 0x28 // R/W
#define MPU9150_I2C_SLV1_REG 0x29 // R/W
#define MPU9150_I2C_SLV1_CTRL 0x2A // R/W
#define MPU9150_I2C_SLV2_ADDR 0x2B // R/W
#define MPU9150_I2C_SLV2_REG 0x2C // R/W
#define MPU9150_I2C_SLV2_CTRL 0x2D // R/W
#define MPU9150_I2C_SLV3_ADDR 0x2E // R/W
#define MPU9150_I2C_SLV3_REG 0x2F // R/W
#define MPU9150_I2C_SLV3_CTRL 0x30 // R/W
#define MPU9150_I2C_SLV4_ADDR 0x31 // R/W
#define MPU9150_I2C_SLV4_REG 0x32 // R/W
#define MPU9150_I2C_SLV4_DO 0x33 // R/W
#define MPU9150_I2C_SLV4_CTRL 0x34 // R/W
#define MPU9150_I2C_SLV4_DI 0x35 // R
#define MPU9150_I2C_MST_STATUS 0x36 // R
#define MPU9150_INT_PIN_CFG 0x37 // R/W
#define MPU9150_INT_ENABLE 0x38 // R/W
#define MPU9150_INT_STATUS 0x3A // R
#define MPU9150_ACCEL_XOUT_H 0x3B // R
#define MPU9150_ACCEL_XOUT_L 0x3C // R
#define MPU9150_ACCEL_YOUT_H 0x3D // R
#define MPU9150_ACCEL_YOUT_L 0x3E // R
#define MPU9150_ACCEL_ZOUT_H 0x3F // R
#define MPU9150_ACCEL_ZOUT_L 0x40 // R
#define MPU9150_TEMP_OUT_H 0x41 // R
#define MPU9150_TEMP_OUT_L 0x42 // R
#define MPU9150_GYRO_XOUT_H 0x43 // R
#define MPU9150_GYRO_XOUT_L 0x44 // R
#define MPU9150_GYRO_YOUT_H 0x45 // R
#define MPU9150_GYRO_YOUT_L 0x46 // R
#define MPU9150_GYRO_ZOUT_H 0x47 // R
#define MPU9150_GYRO_ZOUT_L 0x48 // R
#define MPU9150_EXT_SENS_DATA_00 0x49 // R
#define MPU9150_EXT_SENS_DATA_01 0x4A // R
#define MPU9150_EXT_SENS_DATA_02 0x4B // R
#define MPU9150_EXT_SENS_DATA_03 0x4C // R
#define MPU9150_EXT_SENS_DATA_04 0x4D // R
#define MPU9150_EXT_SENS_DATA_05 0x4E // R
#define MPU9150_EXT_SENS_DATA_06 0x4F // R
#define MPU9150_EXT_SENS_DATA_07 0x50 // R
#define MPU9150_EXT_SENS_DATA_08 0x51 // R
#define MPU9150_EXT_SENS_DATA_09 0x52 // R
#define MPU9150_EXT_SENS_DATA_10 0x53 // R
#define MPU9150_EXT_SENS_DATA_11 0x54 // R
#define MPU9150_EXT_SENS_DATA_12 0x55 // R
#define MPU9150_EXT_SENS_DATA_13 0x56 // R
#define MPU9150_EXT_SENS_DATA_14 0x57 // R
#define MPU9150_EXT_SENS_DATA_15 0x58 // R
#define MPU9150_EXT_SENS_DATA_16 0x59 // R
#define MPU9150_EXT_SENS_DATA_17 0x5A // R
#define MPU9150_EXT_SENS_DATA_18 0x5B // R
#define MPU9150_EXT_SENS_DATA_19 0x5C // R
#define MPU9150_EXT_SENS_DATA_20 0x5D // R
#define MPU9150_EXT_SENS_DATA_21 0x5E // R
#define MPU9150_EXT_SENS_DATA_22 0x5F // R
#define MPU9150_EXT_SENS_DATA_23 0x60 // R
#define MPU9150_MOT_DETECT_STATUS 0x61 // R
#define MPU9150_I2C_SLV0_DO 0x63 // R/W
#define MPU9150_I2C_SLV1_DO 0x64 // R/W
#define MPU9150_I2C_SLV2_DO 0x65 // R/W
#define MPU9150_I2C_SLV3_DO 0x66 // R/W
#define MPU9150_I2C_MST_DELAY_CTRL 0x67 // R/W
#define MPU9150_SIGNAL_PATH_RESET 0x68 // R/W
#define MPU9150_MOT_DETECT_CTRL 0x69 // R/W
#define MPU9150_USER_CTRL 0x6A // R/W
#define MPU9150_PWR_MGMT_1 0x6B // R/W
#define MPU9150_PWR_MGMT_2 0x6C // R/W
#define MPU9150_FIFO_COUNTH 0x72 // R/W
#define MPU9150_FIFO_COUNTL 0x73 // R/W
#define MPU9150_FIFO_R_W 0x74 // R/W
#define MPU9150_WHO_AM_I 0x75 // R
#define MPU9150_CMPS_XOUT_L 0x4A // R
#define MPU9150_CMPS_XOUT_H 0x4B // R
#define MPU9150_CMPS_YOUT_L 0x4C // R
#define MPU9150_CMPS_YOUT_H 0x4D // R
#define MPU9150_CMPS_ZOUT_L 0x4E // R
#define MPU9150_CMPS_ZOUT_H 0x4F // R
int MPU9150_I2C_ADDRESS = 0x68;
int cmps[3];
int accl[3];
int gyro[3];
int temp;
int i=0;
int ledPin = 13;
int ledPin1 = 8;
pinMode(ledPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
Wire.begin();
MPU9150_writeSensor(MPU9150_PWR_MGMT_1, 0);
MPU9150_setupCompass();
int gyro_x=MPU9150_readSensor(MPU9150_GYRO_XOUT_L,MPU9150_GYRO_XOUT_H);
int gyro_y=MPU9150_readSensor(MPU9150_GYRO_YOUT_L,MPU9150_GYRO_YOUT_H);
int gyro_z=MPU9150_readSensor(MPU9150_GYRO_ZOUT_L,MPU9150_GYRO_ZOUT_H);
int accel_x=MPU9150_readSensor(MPU9150_ACCEL_XOUT_L,MPU9150_ACCEL_XOUT_H);
int accel_y=MPU9150_readSensor(MPU9150_ACCEL_YOUT_L,MPU9150_ACCEL_YOUT_H);
int accel_z=MPU9150_readSensor(MPU9150_ACCEL_ZOUT_L,MPU9150_ACCEL_ZOUT_H);
if (((gyro_x>15000)||(gyro_x<-22000))&&((gyro_y>4200)||(gyro_y<-500))&&((gyro_z>1000)||(gyro_z<-13000))&&((accel_x>6000)||(accel_x<-6000))&&((accel_y>4000)||(accel_y<-27000))&&((accel_z>7000)||(accel_z<-200)))
Serial.print("HOMO NAFAL ");
digitalWrite(ledPin, LOW);
digitalWrite(ledPin1, LOW);
i=i+1;
delay(10000);
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin1, HIGH);
if (i==0)
Serial.print(gyro_x);
Serial.print(" “);
Serial.print(gyro_y);
Serial.print(” “);
Serial.print(gyro_z);
Serial.print(” “);
Serial.print(accel_x);
Serial.print(” “);
Serial.print(accel_y);
Serial.print(” ");
Serial.print(accel_z);
delay(100);
//http://pansenti.wordpress.com/2013/03/26/pansentis-invensense-mpu-9150-software-for-arduino-is-now-on-github/
//Thank you to pansenti for setup code.
void MPU9150_setupCompass(){
MPU9150_I2C_ADDRESS = 0x0C; //change Adress to Compass
MPU9150_writeSensor(0x0A, 0x00); //PowerDownMode
MPU9150_writeSensor(0x0A, 0x0F); //SelfTest
MPU9150_I2C_ADDRESS = 0x68; //change Adress to MPU
MPU9150_writeSensor(0x24, 0x40); //Wait for Data at Slave0
MPU9150_writeSensor(0x25, 0x8C); //Set i2c address at slave0 at 0x0C
MPU9150_writeSensor(0x26, 0x02); //Set where reading at slave 0 starts
MPU9150_writeSensor(0x27, 0x88); //set offset at start reading and enable
MPU9150_writeSensor(0x28, 0x0C); //set i2c address at slv1 at 0x0C
MPU9150_writeSensor(0x29, 0x0A); //Set where reading at slave 1 starts
MPU9150_writeSensor(0x2A, 0x81); //Enable at set length to 1
MPU9150_writeSensor(0x64, 0x01); //overvride register
MPU9150_writeSensor(0x67, 0x03); //set delay rate
MPU9150_writeSensor(0x01, 0x80);
MPU9150_writeSensor(0x34, 0x04); //set i2c slv4 delay
MPU9150_writeSensor(0x64, 0x00); //override register
MPU9150_writeSensor(0x6A, 0x00); //clear usr setting
MPU9150_writeSensor(0x64, 0x01); //override register
MPU9150_writeSensor(0x6A, 0x20); //enable master i2c mode
MPU9150_writeSensor(0x34, 0x13); //disable slv4
///////// I2C functions to get easier all values ///////////
int MPU9150_readSensor(int addrL, int addrH){
Wire.beginTransmission(MPU9150_I2C_ADDRESS);
Wire.write(addrL);
Wire.endTransmission(false);
Wire.requestFrom(MPU9150_I2C_ADDRESS, 1, true);
byte L = Wire.read();
Wire.write(addrH);
byte H = Wire.read();
return (H<<8)+L;
int MPU9150_readSensor(int addr){
Wire.write(addr);
return Wire.read();
int MPU9150_writeSensor(int addr,int data){
Wire.write(addr);
Wire.write(data);
Wire.endTransmission(true);
return 1;
