I am using a 20x4 LCD display with an arduino Uno connected to a pH sensor. I have uploaded the code and the LCD text is barley visible. What can i do to fix it?
This is the wiring diagram
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
float calibration_value = 21.34;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10],temp;
lcd.init();
lcd.begin(20, 4);
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print(" Welcome to ");
lcd.setCursor(0, 1);
lcd.print(" Circuit Digest ");
delay(2000);
lcd.clear();
for(int i=0;i<10;i++)
buffer_arr[i]=analogRead(A0);
delay(30);
for(int i=0;i<9;i++)
for(int j=i+1;j<10;j++)
if(buffer_arr[i]>buffer_arr[j])
temp=buffer_arr[i];
buffer_arr[i]=buffer_arr[j];
buffer_arr[j]=temp;
avgval=0;
for(int i=2;i<8;i++)
avgval+=buffer_arr[i];
float volt=(float)avgval*5.0/1024/6;
float ph_act = -5.70 * volt + calibration_value;
lcd.print("pH Val:");
lcd.setCursor(8, 0);
lcd.print(ph_act);
