I am fairly new to Arduino, so apologies in advanced!
I am looking to make an electric go kart. I will be using a 24V 240 watt DC motor powered by a 12V battery. I will be using a throttle to control the speed and would ideally like to have information displayed via an LCD screen such as the current being drawn from the batteries and battery voltage etc.
As i mentioned earlier, assume I know nothing about Arduino (although I have self taught myself the basics and done some basic programming with the Arduino)
So basically I'm just looking for someone to point me in the right direction in regards to the first step to take. Or is this a far to ambitious first project using an Arduino?
for that purpose i bought me some premade modules i just have to connect to the power cables.
, just search for "volt meter" on amazon/ebay, and i am sure lots will show up, and there will sure be "ampere meter" also. find ones in your needed spec ranges.
I got me some of those here for <1€ a piece. So cheap i do not have to worry when i connect them to various little projecs. Checked their values with my laboratory controlled power supply, and they show up nice and correct.
If the stall current is 130A for 24V, it will be 65A at 12V, so an Hbridge capable of 65A
peaks and 15A or so continuous might be a starting point.
You'll find a lot of 24V controllers for wheelchairs and so forth, less at 12V. Prepackaged
controllers have been safety tested and have fail-safe features on the throttle control which
is not something to throw-away lightly.
