system
January 22, 2012, 3:17pm
#1
Hi, I’m trying to use a SPI EEPROM 25lc256 with Arduino, I’m using the SPI library but i don’t know how to use it, so i wrote the code but it doesn’t work it returns me random data…
Here is my code… i think it’s a mess :S
#include <SPI.h>
int variable = 4;
int resultado, registro=0;
SPI.begin();
SPI.setDataMode(SPI_MODE3);
SPI.setClockDivider(SPI_CLOCK_DIV2);
SPI.setBitOrder(MSBFIRST);
SPI.transfer(6);
SPI.transfer(0x10);
delay(5);
for(int j=0; j<9; j++)
SPI.transfer(6);
SPI.transfer(0x20);
SPI.transfer(registro);
SPI.transfer(variable);
delay(5);
SPI.transfer(6);
SPI.transfer(0x30);
resultado = SPI.transfer(0x00);
SPI.transfer(4);
Serial.print("direccion :");
Serial.println(registro);
Serial.println(resultado);
registro++;
variable++;
void loop() {}
thanks for your help
You have to pull the Chip Select / Slave Select line LOW to talk to an SPI device and set it HIGH again when the operation is complete. I don't see that happening in your code.
You seem to be using the command "6" often. That's the Write Enable command but is not the Write command.
You should probably study the datasheet more:
http://ww1.microchip.com/downloads/en/devicedoc/21822e.pdf
system
January 22, 2012, 5:39pm
#3
yes, actually I saw an example with PIC, and they uses write enable several times, I viewed the datasheet before you gave me the link… and I make it work with pic and picaxe, but I don’t know how to use it in Arduino, and the SPI library doesn’t have enough explaination.
How is the chip wired to the Arduino? What pins are connected where?
system
January 22, 2012, 6:25pm
#5
digital pin 10 Arduino - pin 1 25lc256
digital pin 11 - pin 5
digital pin 12 - pin 2
digital pin 13 - pin 6
pin 7, 3 and 8 of 25lc256 to 5v
pin 4 to gnd
That pinout looks correct and means that Pin 10 is being used as the Slave Select (CS) pin. You need to add pinMode(10, OUTPUT); and digitalWrite(10, HIGH); to setup() and then before each command you add digitalWrite(10, LOW); to enable the SPI device. Add digitalWrite(10, HIGH); after al the data for the command has been transferred.
That will get you closer and will make it clear what commands you are sending. It will probably still not work until you issue the right commands. It would probably help if you could put into comments what you expect each part of the code to do.
system
January 22, 2012, 9:17pm
#7
Oh! I see … I think … SPI library that it automatically
I’ll try that…
system
January 22, 2012, 9:39pm
#8
I have to change some code to make it work, but now is working
Thanks!
Now I’ll try to make a writing cycle, and a reading cycle.
#include <SPI.h>
int variable = 2; //data that you want to record
int resultado, registro=0; // variable to record from EEPROM, position of the registry
pinMode(10,OUTPUT);
SPI.begin();
SPI.setDataMode(SPI_MODE3); //setup SPI protocol
SPI.setClockDivider(SPI_CLOCK_DIV2); // 10 Mhz max for 25LC256
SPI.transfer(6); //write enable 6
SPI.transfer(1); //remove block protection 1,0
SPI.transfer(0);
delay(5);
SPI.transfer(2); // write 2,0
SPI.transfer(0);
SPI.transfer(registro); // registry
SPI.transfer(variable); // data
delay(5);
SPI.transfer(6); // write enable 6
SPI.transfer(3); // read 3,0
SPI.transfer(0);
Serial.print("direccion");
Serial.print(registro);
Serial.print(" : ");
registro++;
variable++;
SPI.transfer(4); // write disabled 4
void loop() {}
system
January 22, 2012, 10:01pm
#9
This is the writting cycle:
Note : I added a led to digital pin 2 to show when the cycle is finished.
#include <SPI.h>
int variable = 56; //data to record
pinMode(10,OUTPUT);
pinMode(2,OUTPUT);
digitalWrite(2, HIGH);
SPI.begin();
SPI.setDataMode(SPI_MODE3); // set SPI protocol
SPI.transfer(1); // remove block protection 1,0
SPI.transfer(0);
delay(5);
SPI.transfer(6); // write enabled 6
SPI.transfer(0);
SPI.transfer(variable); // data to record
delay(5);
registro++; // +1
variable++; // +1
digitalWrite(2, LOW);
This is the reading cycle:
#include <SPI.h>
pinMode(10,OUTPUT);
pinMode(2,OUTPUT);
SPI.begin();
SPI.transfer(0);
Serial.print("direccion"); //print on screen
registro++;
