I have reduced your code a little bit (there is more that can be done as you may see but I think it is better to advance in certain steps...):
//#define WOKWI // If this is defined the data are in accordance with the WOKWI stepper (200 steps/revolution)
#define step_pin 3 // Pin 3 connected to Steps pin on EasyDriver
#define dir_pin 2 // Pin 2 connected to Direction pin
#define MS1 5 // Pin 5 connected to MS1 pin
#define MS2 4 // Pin 4 connected to MS2 pin
#define ENABLE 7 // Pin 7 connected to ENABLE pin (active LOW)
#define X_pin A0 // Pin A0 connected to joystick x axis
int direction; // Variable to set Rotation (CW-CCW) of the motor
#ifdef WOKWI
int steps = 100; // Assumes the belt clip is in the Middle
int Positions[5] = {50,75, 100, 125, 150};
#else
int steps = 1025; // Assumes the belt clip is in the Middle
int Positions[5] = {0,512, 1015, 1535, 2050};
#endif
int Thresholds[6] = {0,100,400,600,900,1024};
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(dir_pin, OUTPUT);
pinMode(step_pin, OUTPUT);
pinMode(ENABLE, OUTPUT);
digitalWrite(ENABLE, LOW); // Enable A4988
Serial.println("Enabled!");
delay(5); // Wait for EasyDriver wake up
/* Configure type of Steps on EasyDriver:
// MS1 MS2
// LOW LOW = Full Step //
// HIGH LOW = Half Step //
// LOW HIGH = A quarter of Step //
// HIGH HIGH = An eighth of Step //
digitalWrite(MS1, LOW); // Configures to Full Steps
digitalWrite(MS2, LOW); // Configures to Full Steps
IfWithinThresholdsStepTo(Positions[0], Thresholds[0] , Thresholds[1]);
IfWithinThresholdsStepTo(Positions[1], Thresholds[1]+1, Thresholds[2]);
IfWithinThresholdsStepTo(Positions[2], Thresholds[2]+1, Thresholds[3]);
IfWithinThresholdsStepTo(Positions[3], Thresholds[3]+1, Thresholds[4]);
IfWithinThresholdsStepTo(Positions[4], Thresholds[4]+1, Thresholds[5]);
void IfWithinThresholdsStepTo(uint16_t Position,int lowMargin, int highMargin){
while (analogRead(X_pin) > lowMargin && analogRead(X_pin) <= highMargin) {
if (steps < Position) {
digitalWrite(dir_pin, LOW);
digitalWrite(step_pin, HIGH);
delay(1);
digitalWrite(step_pin, LOW);
delay(1);
steps++;
if (steps > Position) {
digitalWrite(dir_pin, HIGH);
delay(1);
delay(1);
steps--;
I added a #define so that it works also with the Wokwi stepper which has 200 steps/revolution.
This line is already disabled in the sketch above.
See here https://wokwi.com/projects/361241142721306625
Actually the driver board does know nothing about the position of your stepper motor axis nor does your software know it. (It is different with Wokwi as the simulator resets the stepper axis to 0.0Β° with every restart. That usually does not happen in reality. The axis is where it stands at power up unless someone uses sensors to identify the angular position.)
If your stepper moves when you start the sketch the joystick must deliver a value that is not within the center range (401 to 600).
You may check the value of your joystick in setup() and make sure that it is in the center position before you go to loop().
This is a version that waits until you have centered the joystick:
Ask to center Joystick
#ifdef WOKWI
#else
#endif
int Thresholds[6] = {0,100,400,600,900,1023};
// MS1 MS2
Serial.println("Please center Joystick!");
while (!(analogRead(X_pin) > Thresholds[2]+1 && analogRead(X_pin) <= Thresholds[3])){ // if not centered
Serial.print(".");
Serial.println("\nJoystick is centered!");
delay(1);
delay(1);
steps++;
delay(1);
delay(1);
steps--;
See https://wokwi.com/projects/361248704150318081
For further information on the driver board you may download this
A4988 datasheet
