I just bought an ILI9486 LCD in order to use it with an ESP32:
https://fr.aliexpress.com/item/3-5-inch-26P-SPI-TFT-LCD-Display-Screen-with-Touch-Panel-320-480-for-RPi1/32746328272.html
I tried to use it with the TFT_eSPI library. I just wired the LCD like it's written in the Setup11_RPi_touch_ILI9486.h file:
#define TFT_MISO 19
#define TFT_MOSI 23
#define TFT_SCLK 18
#define TFT_CS 15 // Chip select control pin
#define TFT_DC 2 // Data Command control pin
#define TFT_RST 4 // Reset pin (could connect to RST pin)
#define TOUCH_CS 22 // Chip select pin (T_CS) of touch screen
I uncommented #include <User_Setups/Setup11_RPi_touch_ILI9486.h> line in the User_Setup_Select.h file.
When I try to use one of the example in the "480 x 320" directory I just have grey gradient in the screen and nothing else.
The touch pad is well working but not the screen...
What's going wrong?
Thanks in advance for your help
