I have erased all the libraries in « Documents/Arduino/Libraries », then all the folder « Arduino15 » in User/AppData, and uninstalled Arduino IDE.
I have then installed last Arduino IDE 1.8.13 on Windows 10
Then I downloaded :
MCUFRIEND_kbv-2.9.9-Release
Adafruit-GFX-Library-master
I then opened Arduino.exe, to install those two libraries
I modified the following lines in the programs :
Edit mcufriend_shield.h: #define USE_SPECIAL
Edit mcufriend_special.h: #define USE_MEGA_8BIT_PORTC_SHIELD
I then ran the LCD_ID_Reader.ino program
Isn’t it strange it says version 2.9.8 even if the 2.9.9 is installed ?
Here are my settings for the Arduino MEGA :
I modified the graphictest_kbv.ino program : (7796)
When I compile the graphictest_kbv.ino program, I have the following errors :
In file included from C:\Users\S�bastien\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:16:0,
from C:\Users\S�bastien\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:35:
C:\Users\S�bastien\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_special.h:529:2: warning: #warning USE_MEGA_8BIT_PORTC_SHIELD for Mihael54 [-Wcpp] #warning USE_MEGA_8BIT_PORTC_SHIELD for Mihael54
In file included from C:\Users\S�bastien\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:35:0:
C:\Users\S�bastien\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:18:2: warning: #warning WE ARE USING A SPECIAL CUSTOM DRIVER [-Wcpp] #warning WE ARE USING A SPECIAL CUSTOM DRIVER
What is LCD_ID_Reader.ino ?
There is no example called this.
Please do not post screenshots. It is really annoying to download several images. I can't read them without "magnify". I can't copy-paste them.
You seem to have installed libraries. Made the correct SPECIAL edits.
Please run graphictest_kbv.ino example. Your edit looks ok.
What ID is reported on Serial Terminal ?
What graphics are displayed on the screen ?
Please edit line #47 of diagnose_TFT_controller.ino
uint16_t guess_ID = 0x7796; // write-only shield
Build and Run diagnose_TFT_controller.ino
Copy-paste from the Serial Terminal.
If you have only got White screens, please post a photo of your pcb.
I need to see how many integrated circuits. And any configuration links.
i.e. does the item on your desk match the photos in the LCDWIKI link from #0 ?
first of all I have to say thank you for your patience, and my problem is solved !
I think that everything was allready solved thanks to your first reply… but I thought that having red warning lines when I was building the program could make my Arduino MEGA having troubles, so I didn’t uploaded it to the Arduino.
I did upload it to give it a try, and everything works fine !
“What is LCD_ID_Reader.ino ?” ==> Sorry I meant “diagnose_TFT_support”
I have taken pictures of my display screen and my arduino MEGA just if it could help other people.
My screen pcb is the same as shown in #0
Yes, it is very important to get the spelling correct. You can always edit your posts to correct any typos. If it is a major edit, just make a note to explain your changes.
The following ones work fine when forcing id “0x7796”
Font_simple
scroll_kbv
testcard_kbv
I am now interested in making the touchscreen work … none of the examples worked :
button_simple
Problem : C:\Users\SBASTI~1\AppData\Local\Temp\arduino_modified_sketch_548030\button_simple.ino: In function ‘void setup()’:
C:\Users\SBASTI~1\AppData\Local\Temp\arduino_modified_sketch_548030\button_simple.ino:55:75: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
on_btn.initButton(&tft, 60, 200, 100, 40, WHITE, CYAN, BLACK, “ON”, 2);
C:\Users\SBASTI~1\AppData\Local\Temp\arduino_modified_sketch_548030\button_simple.ino:56:77: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
off_btn.initButton(&tft, 180, 200, 100, 40, WHITE, CYAN, BLACK, “OFF”, 2);
diagnose_Touchpins
Monitor says: Making all control and bus pins INPUT_PULLUP
Typical 30k Analog pullup with corresponding pin
would read low when digital is written LOW
e.g. reads ~25 for 300R X direction
e.g. reads ~30 for 500R Y direction
Screen still white
(I’ve tried to touch my screen, nothing happened)
TouchScreen_Calibr_native
libraries\MCUFRIEND_kbv\TouchScreen_kbv.cpp.o (symbol from plugin): In function TSPoint_kbv::TSPoint_kbv()': (.text+0x0): multiple definition of TSPoint_kbv::TSPoint_kbv()’
sketch\TouchScreen_kbv.cpp.o (symbol from plugin):(.text+0x0): first defined here
libraries\MCUFRIEND_kbv\TouchScreen_kbv.cpp.o (symbol from plugin): In function TSPoint_kbv::TSPoint_kbv()': (.text+0x0): multiple definition of TouchScreen_kbv::TouchScreen_kbv(unsigned char, unsigned char, unsigned char, unsigned char)’
libraries\MCUFRIEND_kbv\TouchScreen_kbv.cpp.o (symbol from plugin): In function TSPoint_kbv::TSPoint_kbv()': (.text+0x0): multiple definition of TouchScreen_kbv::pressure()’
collect2.exe: error: ld returned 1 exit status
exit status 1
