3 LEDs controlled by 3 Separate Buttons (not working)
Hi there,
I'm new to Arduino and I am working on a project for class. I would like each LED to be controlled by a separate button. (3 LEDs/ 3 Buttons).
I've tried everything, but no matter what I do all 3 LEDs are controlled by one button. :sob: If anyone could please help I would appreciate it so much! (using the Arduino Uno)
Code here:
// constants won't change. They're used here to set pin numbers:
const int button1Pin = 2;     // the number of the pushbutton pin
const int led1Pin =  11;      // the number of the LED pin
const int button2Pin = 3;     // the number of the pushbutton pin
const int led2Pin =  12;      // the number of the LED pin
const int button3Pin = 4;     // the number of the pushbutton pin
const int led3Pin =  13;      // the number of the LED pin
// variables will change:
//BUTTON 1 AND LED 1 HERE ------------------------------------
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(led1Pin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(button1Pin, INPUT);
  //LED 2------------------------------------------------------
  pinMode(led2Pin, OUTPUT);
  pinMode(button2Pin, INPUT);
  //LED 3-------------------------------------------------------
  pinMode(led3Pin, OUTPUT);
  pinMode(button3Pin, INPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(button1Pin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // LED 1---------------------------------------------------------------------------------
    //turn LED on:
    digitalWrite(led1Pin, HIGH);
    digitalWrite(led2Pin, LOW);
    digitalWrite(led3Pin, LOW);
    //LED 2--------------------------------------------------------------------------------------
    digitalWrite(led2Pin, HIGH);
    digitalWrite(led1Pin, LOW);
    //LED 3--------------------------------------------------------------------------------------
    digitalWrite(led3Pin, HIGH);
You have one button state controlling all of the three LEDS
after the first LED control put
buttonState = digitalRead(Button2Pin)
after the Second LED control put
buttonState = digitalRead(Button3Pin);
const byte button1Pin = 2;     // the number of the pushbutton pin
const byte led1Pin =  11;      // the number of the LED pin
const byte button2Pin = 3;     // the number of the pushbutton pin
const byte led2Pin =  12;      // the number of the LED pin
const byte button3Pin = 4;     // the number of the pushbutton pin
const byte led3Pin =  13;      // the number of the LED pin
byte buttonState1 = 0;         // variable for reading the pushbutton status
byte buttonState2 = 0;         // variable for reading the pushbutton status
byte buttonState3 = 0;         // variable for reading the pushbutton status
  pinMode(button1Pin, INPUT_PULLUP);
  pinMode(button2Pin, INPUT_PULLUP);
  pinMode(button3Pin, INPUT_PULLUP);
  buttonState1 = digitalRead(button1Pin);
  buttonState2 = digitalRead(button2Pin);
  buttonState3 = digitalRead(button3Pin);
  if (buttonState1 == HIGH) {
    //turn LED on:
if (buttonState2 == HIGH)
if (buttonState3 == HIGH)
FYI
https://europe1.discourse-cdn.com/arduino/optimized/4X/a/f/d/afd79a456ca61b3da273c900f13fa9cf052850a2_2_569x500.jpeg
Hi Larry,
Thank you for your response. I appreciate your help.
However a problem still persists where after I run the code, all of the LEDs stay on and eventually turn off and back on (I think it's following the loop part of the code). If I press any button only the first LED (red) brightens slightly. Do you have any advice?
I'm gonna attach a picture so you can see what I mean. (I know the breadboard looks chaotic LOL this is the biggest one my school has)
Show us a good schematic of your proposed circuit.
Is the green wire going to 5v ?
Check the syntax for if( )
if( . . . )
    //do something
    //do another thing
    //do one last thing
    //turn LED on:
Trying it out, but I'm getting an error called
exit status 1
expected '}' at end of input
Code I am putting in:
    //turn LED on:
Count your { and }, they should be equal.
Tom... :grinning: :+1: :coffee: :australia:
Also:
Yes, it is. I'm trying to add a picture but it's not working. :sob: I'll send another reply if it goes through..
But for the breadboard, I was trying to use this image as a reference, but adding a third one. (which might be backfiring on me hahaha)
Image of Arduino:
You are plugged into the 3.3 volt hole.
Move the green wire end Down to 5V.
And remember every { needs a friend }
Oh! I fixed it, it was just missing a } at the end.
Do you have any advice if they are all still lighting up for every button? They all slightly light up more when a button is pressed.
Updated code:
    //turn LED on:
Hello
Try and check out this modification to your code:
  // switch LED with related button:
  digitalWrite(led1Pin, !digitalRead(button1Pin));
  digitalWrite(led2Pin, !digitalRead(button2Pin));
  digitalWrite(led3Pin, !digitalRead(button3Pin));
Have nice day and enjoy coding in C++.
p.s.
This is a nice task to start to use OOP.
The object is the LED with related button and the method takes care about the action to be done.
Hi Paul,
Thank you so much for your reply! I'm trying it out, and it's a lot better. The only thing is that all of the pushbuttons are controlling the red LED (pin 11).
Hmm.. I'm gonna have to check this out. My class has only covered the basic examples Arduino provides inside the program, so this is all new to me ahaha
Can you try this bit of code please?
All it does is cycle each LED ON then OFF, there should only be ONE LED on at a time.
  // cycle each LED in turn
How have you got your buttons wired now.
Can you please post a circuit diagram and picture of your project.?
Is it still the same as in post #11?
If so you are using pull down resistors and the code is for internal pull_up resistors.
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
Hi Tom!
Yes this code is a lot better, just have to figure out how to get it to the other LEDs.
Yes it is still the same. I'm not sure how to create one, but it is following this diagram with an extra LED and button. I can try to place the LEDs and buttons in a different layout if that would be beneficial though.
Also, in the code, is it possible to switch "pull_up" to "pull_down"?
SO does my code just flash each LED in turn?
Sorry but there is no pull-down in software.
Change ;
to
  pinMode(button1Pin, INPUT);   //<<<<<<
  pinMode(button2Pin, INPUT);  //<<<<<<
  pinMode(button3Pin, INPUT);  ??<<<<<
You have pull down resistors on your protoboard, leave them there in circuit.
Then try your code.
Yes it was flashing with the other code posted. Each button seemed to be connected to the first LED (pin11). If any button was pressed, it would temporarily stop the LED from flashing but would come back.
The code you just sent stopped the flashing though. The first LED is off, but if any button is pressed it turns on. The other LEDs aren't working yet.
Hello and good morning
Post the current hardware layout.
