3 phase STAR-TRIANGLE ( Y/Δ ) motor. Help to compile 2 buttons and 3 releys
//INPUTS
int buttonInput1 = 3; //button N/O START
int buttonInput2 = 4; //button N/C STOP
//OUTPUTS
int lightOutput1 = 5; //RELAY CENTRAL
int lightOutput2 = 6; //RELAY STAR
int lightOutput3 = 7; //RELAY TRIANGLE
//INPUTS CONDITION
int buttonstate1 = 0; //button N/O START CONDITION
int buttonstate2 = 1; //button N/C STOP CONDITION
void setup(){
//INPUTS
pinMode(3,INPUT); //Button N/O START
pinMode(4,INPUT); //Button N/C STOP
//OUTPUTS
pinMode(5,OUTPUT); //RELAY CENTRAL
pinMode(6,OUTPUT); //RELAY STAR
pinMode(7,OUTPUT); //RELAY TRIANGLE
void loop(){
buttonstate1 = digitalRead(1); //read condition of N/O button and connect it with PIN 3
if (buttonstate1 == HIGH){
digitalWrite(5,HIGH); //RELAY CENTRAL
digitalWrite(6,HIGH); //RELAY STAR
digitalWrite(7,LOW); //RELAY TRIANGLE
buttonstate2 = digitalRead(0); //read condition of N/C button and connect it with PIN 4
if (buttonstate2 == LOW){
digitalWrite(5,LOW); //RELAY CENTRAL
digitalWrite(6,LOW); //RELAY STAR
HOW TO COMPILE BUTTONS with OUTPUTS(releys)???? please help me to finish that
pinMode(1,INPUT);       //Button N/O START
Why is the switch connected to the serial port pin? How can you debug your code that way? Debug by guesswork takes way longer than debug by fact.
i didn't pay attention that the "pin 1" was serial...thank you.I will change it. can you help me to compile relays with buttons?
No. I can't see what error messages you are seeing.
by the time i will keep by my self...if I will have questions i'll ask you))
Firstly, please put your code into code tags.
Secondly, a y/d start is not a good way to start a three phase motor for a number of reasons:
  • You will get two current spikes almost as high as the single one in direct start
  • The motor will have a starting torque of 1/3 of the direct start torque meaning that that starting time is prolonged resulting in increased heat up.
Y/D start IS appropriate when starting devices with large inertia such as rotational converters and tooling machinery where there is large inertia but no load on start.
The best way to do a Y/D start is designing a state machine as the one in the attached state diagram. This can then easily be coded using my state machine library
#include <SM.h>
SM ydStart(off);
enum {onBtn = 2, offBtn, cRelay, wRelay, dRelay};//declare I/O pins
void setup(){
  for(int pin = cRelay; pin<=dRelay; pin++) pinMode(pin, OUTPUT);//relay pins as outputs
}//setup()
void loop(){
  EXEC(ydStart);
}//loop()
State off(){
  if(digitalRead(onBtn)){
    ydStart.Set(wye);
    digitalWrite(cRelay, 1);//central realy on
    digitalWrite(wRelay, 1);//wye relay on
  }//if(onBtn)
}//off()
State wye(){
  checkOff();
  if(ydStart.Timeout(1000)){
    digitalWrite(wRelay, 0);
    ydStart.Set(ccp);
  }//if(timeout)
}//wye()
State ccp(){
  checkOff();
  if(ydStart.Timeout(20)){//20ms for cross conduct prevention
    digitalWrite(dRelay, 1);
    ydStart.Set(delta);
}//ccp()
State delta(){
  checkOff();
}//delta()
void checkOff(){
  if(digitalRead(offBtn)){//check off btn
    for(int pin = cRelay; pin<=dRelay; pin++) digitalWrite(pin, 0);//all relays off
    ydStart.Set(off);
  }//if(offBtn)
Thank you Nilton. You help me a lot!!!)))) :smiley:
