3 Phase Voltage Monitoring Using ESP32 and 2 or more ZMPT101B
Hi there, I’m totally new here.
I am attempting to build 3 phase voltage monitoring with ZMPT101B sensors. The issue is that i can not write the code to make it read 2 or more analogue sensors.
I am using the ESP32 .
This is the code needed for the Voltage sensor
#include <Filters.h>
float testFrequency = 50;                     // signal frequency (Hz)
float windowLength = 40.0/testFrequency;     // how long to average the signal, for statistist
int Sensor = 0;
float intercept = -0.04;  // adjust untuk kalibrasi
float slope = 0.0964;   // adjust untuk kalibrasi
float current_Volts;
unsigned long printPeriod = 1000;     //Refresh rate
unsigned long previousMillis = 0;
  Serial.begin( 9600 );
  Serial.println("AC Voltmeter");
  //delay(5000);
  RunningStatistics inputStats;
  inputStats.setWindowSecs( windowLength );
  while( true ) {
    Sensor = analogRead(A0);                // read the analog in value:
    inputStats.input(Sensor);                   // log to Stats function
    if((unsigned long)(millis() - previousMillis) >= printPeriod) {
      previousMillis = millis();                // update time every second
      current_Volts = intercept + slope * inputStats.sigma(); //Calibartions for offset and amplitude
      current_Volts= current_Volts*(49.3231);                //Further calibrations for the amplitude
      Serial.print( "Voltage: " );
      Serial.println( current_Volts );
And this is i’m trying to do to read 2 analogue sensors
float windowLength = 100.0/testFrequency;     // how long to average the signal, for statistist
int Sensor1 = 0;
int Sensor2 = 0;
float intercept = 0;  // adjust untuk kalibrasi
float slope = 0.01245;   // adjust untuk kalibrasi
float Tegangan1;
float Tegangan2;
  //delay(5000);
void phase1() {
  while( true ) {
    Sensor1 = analogRead(34);                // read the analog in value:
    inputStats.input(Sensor1);                   // log to Stats function
      Tegangan1= (intercept + slope * inputStats.sigma())*(49.3231); //Calibartions for offset and amplitude
      Serial.print( "Tegangan 1: " );
      Serial.println( Tegangan1 );
  delay(700);
void phase2() {
  while( true ) {
    Sensor2 = analogRead(35);                // read the analog in value:
    inputStats.input(Sensor2);                   // log to Stats function
      Tegangan2= (intercept + slope * inputStats.sigma())*(49.3231); //Calibartions for offset and amplitude
      Serial.print( "Tegangan 2: " );
      Serial.println( Tegangan2 );
  delay(700);
  phase1();
  phase2();
Anyone can help?
Can you read ONE sensor with the ESP32?
What controller is the first code for?
Have you tried the first code in the controller it was meant for?
I can see your have made two functions which is what I would do, but have you just got one to work?
What result do you get with your second code?
Can I suggest you also change the Serial.begin to 115200, its so much faster and 9600 is an old industrial standard.
Tom... :smiley: :+1: :coffee: :australia:
Yes i can, i use first code and modified it with my preference
I use esp32 in all this project
Have you tried the first code in the controller it was meant for.
I did and it works
On the second code, it only read the first sensor
It only read 1 sensor, the second sensor isn't appear
Pada tanggal Sab, 21 Mei 2022 12.32, TomGeorge Believes in the Lucas Smoke Theory. via Arduino Forum <arduino@discoursemail.com> menulis:
I see the ZMPT101B gives you the voltage
if you also require current I have found a SCT-013 current clamp suitable to monitor the three phase grid supply to the house
I assume you are using the ZMPT 101 B Module to offset the AC voltage so it is suitable for sampling with an Arduino ADC?
Can you please post a circuit diagram of your circuit?
Please include the 3phase supply, and component manes and pin labels.
Thanks.. Tom.... :smiley::+1: :coffee: :australia:
Hi guys, my code already working. Thank you for your help. But i don't know if it can working to measuring 3 phase voltage. i have not try yet. Here is my code.
int Sensor = 0;
int Sensor2 = 0;
int Sensor3 = 0;
int Sensor4 = 0;
int Sensor5 = 0;
int Sensor6 = 0;
float slope = 0.25731;   // adjust untuk kalibrasi
float A;
float B;
float C;
float D;
float E;
float F;
  Serial.begin( 115200 );
  Serial.println("3 Phase Voltage Monitor");
  //delay(5000);
  RunningStatistics inputStats,inputStats2,inputStats3,inputStats4,inputStats5,inputStats6;
  while( true ) {
    Sensor = analogRead(34);                // read the analog in value:
    inputStats2.input(Sensor2);                   // log to Stats function
    Sensor3 = analogRead(32);                // read the analog in value:
    inputStats3.input(Sensor3);                   // log to Stats function
    Sensor4 = analogRead(33);                // read the analog in value:
    inputStats4.input(Sensor4);                   // log to Stats function
    Sensor5 = analogRead(25);                // read the analog in value:
    inputStats5.input(Sensor5);                   // log to Stats function
    Sensor6 = analogRead(26);                // read the analog in value:
    inputStats6.input(Sensor6);                   // log to Stats function
      A = intercept + slope * inputStats.sigma(); //Calibartions for offset and amplitude
      B = intercept + slope * inputStats2.sigma(); //Calibartions for offset and amplitude
      C = intercept + slope * inputStats3.sigma(); //Calibartions for offset and amplitude
      D = intercept + slope * inputStats4.sigma(); //Calibartions for offset and amplitude
      E = intercept + slope * inputStats5.sigma(); //Calibartions for offset and amplitude
      F = intercept + slope * inputStats6.sigma(); //Calibartions for offset and amplitude
      Serial.print( "Tengangan R-S: " );
      Serial.println( A );
      Serial.print( "Tengangan S-T: " );
      Serial.println( B );
      Serial.print( "Tengangan R-T: " );
      Serial.println( C );
      Serial.print( "Tengangan R-N: " );
      Serial.println( D );
      Serial.print( "Tengangan S-N: " );
      Serial.println( E );
      Serial.print( "Tengangan T-N: " );
      Serial.println( F );
Can you post an image of a hand drawn circuit of how you propose to connect your project to 3phase circuit?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Maybe like this
Pada tanggal Min, 22 Mei 2022 14.13, TomGeorge Believes in the Lucas Smoke Theory. via Arduino Forum <arduino@discoursemail.com> menulis:
What is the voltage spec of the ZMPT101B?
What is your phase to phase voltage, hence what is your phase to neutral voltage?
Do you want to measure phase to phase voltage or phase to neutral voltage?
I want to measure both phase to phase voltage and phase to netral voltage. I want to apply it at the distribution substation. Is it possible to use the zmpt101b sensor?
Phase to phase voltage is related to phase to neutral
One is root 3 times the other, so no need to measure both .
That sensor is not for “ industrial “ use , it’s a hobby part . I would not use for anything other than hobby use , and then take precautions .
Buy a proper 3ph voltmeter and get a qualified person to install it . You can then use any output it may have .
The phase to phase voltage will exceed its rating if it’s a” 240v “ setup .
If it’s 415v then it’s definite not usable
Examples
Have you looked at the specs for the ZMPT?
I think you will find it is 240Vac.
What is your phase to phase voltage?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
