What I am trying to programmate ?
- I build up table tennis robot like robopong,butterfly ammicus etc...
-If I tryed to motors sepparatelly everything was great, but If I used everything in whole one arduino program, everymotor was freezing and not work properly.
I need help please. I am a newbie in arduino programming and I am using much delays and then everything freezes and is delayed.
Please help me to rewrite the arduino code. Thank you very much.
#include <Servo.h>
Servo servo1; // feed servo
Servo motor1; // brushless main motor
Servo otacachor; // horizontal rotation servo
int malymot =12; //small motor,helps feed servo to feed balls
int led = 13; //just led
int potpin1 = A0; // potenciometer for main brushless motor
int potpin2 = A3; // potenciometer for servomotor(servo1) (feed servo)
int potpin3= A5; //potenciometer for horizontal rotation servo
int val1 ; // motor1
int val2; // servomotor
int val3; // motor for horizontal rotation
int random1; //randomizer for servo
int random2; //randomizer for horizontal motor
int toogleservo1 = 5 ; //toogle switch for activate the randomizer for feed servo
int toogleservo2= 6; //toogle switch for activate the randomizer for horizontal rotation servo
{ pinMode(led, OUTPUT);
pinMode(malymot, OUTPUT);
pinMode (toogleservo1, INPUT);
pinMode (toogleservo2, INPUT);
motor1.attach(9); // attaches the servo on pin 9 to the servo object
servo1.attach(3);
otacachor.attach(11);
{ int toogleservo1ON = digitalRead (toogleservo1);
val2 = analogRead(potpin2); // reads the value of the potentiometer (value between 0 and 1023)
val2 = map(val2, 0, 1023, 2000, 500); //waiting between 0,5 - 2sek
if (toogleservo1ON == HIGH){ // randomizer for horizontal servo
random1 = random (500,2000);
servo1.write (172);
delay (500);
servo1.write (30);
delay(random1);
digitalWrite(malymot, HIGH);
digitalWrite(led, LOW);}
else if (val2 > 1900){ //val2 is for potentiometer just to stop the feed servo
servo1.write (30);
delay (15);
digitalWrite(malymot, LOW);
digitalWrite(led, HIGH);}
else if (val1<110){ //to not feed the robot until the brushless motor doesnt work
servo1.write (30);
delay (15);
else {
servo1.write (172);
delay (500);
servo1.write (30);
delay(val2);
val1 = analogRead(potpin1); // the main brushless motor
val1 = map(val1, 0, 1023, 60, 170);
motor1.write(val1);
delay (15);
int toogleservo2ON = digitalRead (toogleservo2);
val3= analogRead(potpin3); // horizontal rotation servo
val3 = map(val3,0,1023,0,180);
otacachor.write(val3);
delay(15);
if (toogleservo2ON == HIGH){ // randomizer for horizontal servo
random2 = random (70,110); //random the angle of rotation
otacachor.write (random2);
delay (val2); //to delay the time the feed servo delays
