34pin IDE connector to wiring loom... how?
I have a circuit board with a 34 pin IDE connector on (socket). I know these usually use a ribbon cable to connect to - is there a way to connect this to a non ribbon cable? I'm going to need to plug it into my wiring loom in my car...
Thanks!
Can't answer without photo
(top & bottom)
450nick:
Thanks!
No, the IDE connector is designed specifically for 0.05" pitch ribbon cable.
Can you separate the ribbon cable into individual wires along part of its length ?
Do you need all 34 wires or only some of them ?
How are you going to connect it to the car wiring loom ?
He didn't say he he had a cable.
He said he had aconnector.
Sorry chaps, my bad. I am designing a PCB, and am using IDE sockets to allow termination of IDE ribbon cables to the board from existing vehicle switchpacks. I then need a I/O connector to interface the board with the car and used IDE simply because I was already using it. I now realise that limits me to ribbon cables which won't interface with the car loom very easily.
In which case, which would be a nice replacement which would take up roughly the same board space?
Currently I have this socket https://tz.infinite-electronic.hk/product/HARTING_09185347324.aspx
Could anyone recommend a part which would work for wire to board rather than board to board?
You still haven't said how the wires/cables "interface" with the car loom. You could, for instance, create a small PCB with an IDE connector to accept the ribbon cable from your main PCB with outputs to suitable connectors to "interface" with the car loom
Plug a cable in and split the wires and splice them into the 'loom' (whatever that means)
cut connector off one end of this:
https://www.ebay.com/i/251599561635?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=251599561635&targetid=649162909567&device=m&mktype=pla&googleloc=9032179&poi=&campaignid=6470719337&mkgroupid=83197471888&rlsatarget=pla-649162909567&abcId=1140476&merchantid=101723062&gclid=EAIaIQobChMI9NG3oYHH5gIV7x-tBh2kZwpZEAQYASABEgKDqfD_BwE
UKHeliBob:
Well ideally I would terminate some wires from the dashboard loom/harness to crimp pins to be inserted into a connector which would plug into the board.
I could make a small interface board but that then adds a ribbon cable and a small pcb that isn't needed. Better to terminate directly into the pcb if possible. I just seem to be struggling to find something like this in on the component websites..
https://www.jst.co.uk/productSeries.php?pid=16624&cat=30
