Hi all, I'm currently working on a project where I'd like to have two bar-like matrices of 3x10 leds for some lighting effects on two sides of a box. I'm going at this with no formal training and have only picking up a formula here and there, so endure the simple questions.
I did research for a few days, but I'd just like a little individual project guidance, what I guess this forum section is for.
Some info:
- I don't need to control them individually, I just want to turn all of them off and on and control brightness (I'm getting audio levels from a mic and want to adjust the brightness accordingly)
- I have limited space, about 2 x 4 cm on which to put chips, so I'd like a chip that does it all and that I can chain two of if needed
- Leds are these rgb rainbow leds with timer chip and only two pins. Max Voltage: 3.8V, Max Current: 30mA. If it helps, here the link where I bought it from (all in German sorry): http://ebay.eu/1asnT4E
So, what have I tried/done: I started with the common 74HC595 shift register, thought I could just daisy chain two of them. I then found out I'd need some transistors to sink the current(?) and even with a darlington array that would again exceed the space. Then I looked into LED drivers like the MAX7219/MAX7221, getting lots of info from here http://forum.arduino.cc/index.php?topic=53152.0, which I guess would be the logical next step. But then I had this thought whether it'd be possible to put each of the three rows in series and just connect the last led pins through some resistors/transistors to the Arduino, although even looking here http://forum.arduino.cc/index.php/topic,12429.0.html didn't really answer my question.
So, summing up:
Is it possible to use the Leds in series through some resistors/transistors like I suggested? That would mean 6 rows (2 matrices remember) of 10 leds with pretty high values connected to the Arduino Uno. I don't know much about EE yet, but I guess that's absurd? Or not? It'd be the easiest for me that's why I'm asking.
If not possible, what driver chip would fit for this kind of matrix? From what I gathered the MAX drivers are awesome all-rounders, also for this type of 3 x 10 matrix? Chaining two? Is this the most efficient solution then?
Thanks a lot really to anybody, I usually just research the hell out of something but the questions and uncertainties stacked up with this one, thank you ![]()
