I took a look at post #42 from @outsider and matched the wiring to that now.
I have the ground wire connected to the same location where the blue wire from the power supply is connecting.
The Arduino analog output wire doesn't have anything else connected there, except for the opposite side of that terminal where the sensor ground and 250 ohm resistor are connected.
This other post seems to show the same thing.
reading 4-20 mA pressure sensor
In another post of mine I have analog out connected right before 10 kohm resistors. hook up to ground.
I tried that and I got the same 0 results.
