Pressure transducer code
Hi people,
I have a three wire 5v ebay pressure transducer rated to 1.2MPa (174psi) and am looking to verify that the code I have is correct. There seems to be a decent readout on the display, but I am unsure if this is the best way to program this sort of input.
The object is to have a readout in psi, I have this done by scaling an analog input as the transducer puts out a voltage based on it's readings.
For now it displays ~17psi on the readout ambient. I'm unsure if this is because the transducer reads ambient pressure or if it can have a relative zero at ambient?
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const int analogPin = A0;
float inputP1;
float outputP1;
  lcd.begin(20, 4);
  lcd.clear();
  inputP1 = analogRead(A0);
  outputP1 = ((float)inputP1/1024*175);
  // Divide by 1024 for arduino input - multiply by 175 as transducer reads 0 to 175psi
  lcd.setCursor(0,0);
  lcd.print("P1:");
  lcd.setCursor(4,0);
  lcd.print(outputP1);
  lcd.setCursor(0,1);
  lcd.print("A0:");
  lcd.setCursor(5,1);
  lcd.print(inputP1);
  delay (500);
Thanks in advance
Without a link to the transducer, we'd only be guessing. Personally, I'm not into guessing games.
Apologies, here's the link to the type I have:G1/4" inch 5V 0-1.2 MPa Pressure Transducer
(Useless) e-bay links don't count.
Did the link not work? Or is the information provided just useless?
That's about all the information I have on the sensor unfortunately.
Here is the specification from your link:
Working Voltage: 5VDC
Output Voltage: 0.5-4.5 VDC
Sensor material: Carbon steel alloy
Working Current: ≤10 mA
Working Pressure Range: 0-1.2 MPa
The Biggest Pressure: 2.4 MPa
Cable length: 19cm
Destroy Pressure: 3.0 MPa
Working TEMP. Range: 0-85℃
Storage Temperature Range: 0-100℃
Measuring Error: ±1.5 %FSO
Temperature Range Error: ±3.5 %FSO
Response Time: ≤2.0 ms
Cycle Life: 500,000 pcs
Application: non-corrosive gas liquid measurement
but where did you get the formula:
Your formula appears to assume that the transducers delivers (linearly) between 0 and vcc for a pressure range 0 to 175 psi
I thought that's how they worked, but I guess that isn't the case? I'm not very familiar with sensors and programming.
I think in your case, if the sensor delivers 0.5 volts to 4.5 volts to represent 0 to 175 psi and if vcc = 5 volts, then outputP1 = ( inputP1 - 102 ) *175 / 818 (if my school day maths has not let me down too badly).
Seems to output a reasonable value now. (minus the noise from the cheap chinese sensor)
I am not sure however where the 818 comes from in the code. Perhaps my school math has let me down.
Well, it's better to calibrate a sensor than to assume, anyway.
aarg:
I'm looking to have the sensor set up in a test rig once I get the code sorted out to see how accurate it really is. I have two of these and there's a variance of 2psi at ambient pressure already.
I mean calibrate in software.
These ratiometric sensors output 0.1 x Vcc upto 0.9 x Vcc for full scale. You can calculate
the value for a full-scale of F thus:
  int raw = analogRead (pin) ;
  float value = (raw  / 102.4 - 1) * F / 8 ;
I'm glad it seems to give a reasonable answer.
The problem is exactly like converting Fahrenheit to centigrade for water temperature.
The Fahrenheit scale goes from 32 to 212 and centigrade goes from 0 to 100 so the formula is C= (F-32) * (5/9)
The (5/9) comes from 100/(212 - 32).
In your case, the analog reading goes from 0 to 1023 for (in this case) a 5 volt supply. Your sensor delivers 0.5 volts for 0 PSI and 4.5 volts for 175 PSI according to the data sheet.
0.5 volts is an analog reading of 102 (rounded) for 0 PSI
4.5 volts is an analog reading of 921 (rounded) for 175 PSI
so the formula is Pressure (PSI) = ( Analog Reading - 102 ) * 175 / ( 921 - 102 )
which, allowing for rounding errors, is where my 818 came from.
921 - 102 = 818?
Your calculator needs new batteries.
PaulS:
921 - 102 = 818?
I use it for calculating my pay. It always rounds in my favour.
6v6gt:
Base pay = 921.
Deductions = 102.
Resulting pay = 818.
That is rounding on your favor?
Yes. That is what I present for tax.
6v6gt:
Damned high tax bracket... 8)
hi wwiitteekk,
I have the same project using this transducer. Can you help me for the latest code in order to read and convert the sensor.
Thank you
