4-20mA output from Arduino Due DAC
I need to add 4-20mA (current-regulated) outputs to my Due project. I did a little snooping around and found TI's XTR110 IC which is specifically made for converting voltage to current (e.g. 1-5V to 4-20 mA). Problem is, it's for 5V, and the Due works with 3.3V (max 5/6ths of that for the DAC from the SAM3X datasheet). Couldn't find a similar IC that works with that, so I figured I'd just use an opamp like in the following link: http://www.allaboutcircuits.com/textbook/semiconductors/chpt-8/voltage-to-current-signal-conversion/
Current plan is to get a 741 IC and a voltage inverter IC to provide the needed negative voltage to the op-amp. Instead of 250 ohms for the resistance, it'll be (5/6 * 3.3)/(20 mA) = 137.5 ohms. Is this a solid plan or is there a better route to go? I was really hoping to use something like the XTR110 which seems like it'd be more reliable and accurate than just a single op-amp.
Thank you for your help!
Better option single power rail-to-rail:
TS922 or similar
No direct experience in this, but reading the datasheet, I think you can use the XTR110.
Just use it in the standard 0-5volt in config.
And adjust the span for 30.3mA with 5volt in.
That will give you 20mA with 3.3volt in.
Leo..
Wawa:
Leo..
Thanks Wawa, I think you're right after looking further.
http://www.analog.com/media/en/technical-documentation/data-sheets/AD421.pdf
Thanks Wawa. After poking around on their website, I'm going to use the AD5420. Thanks!!!
You can see my simple circuit on Arduino Playground and the complete project on my blog;
