I am current working on a 4 digit 7 seg 5461AS-1. I have made it kind of work and i can count, made a beep when reaching 0 so on. I have an issue tho, The segment B is weird for D2,D3. When projecting a one on D2 its working but kinda dark for seg B, when proejcting another digit with more segment on its like totaly off, and I have tried so much but cant figure out what it could be.
I have a similar problem for seg F for D1-D3. The first digit (D4) is always working tho for some reason. Also I have NOT damaged any segments, all are working when using them seperately with 5V, resistor, GND. Might be good to use a shiftregister with stronger power supply, I would guess that could help but I see so many others getting it to work all from arduino. Using Arduino Uno btw.
I have been working on this issue for a while now and would love to get any help there is!
A = 2, B = pin 3 etc
The segment for the display is like this picture bellow, but I ofcourse hasnt connected it like the pictures numbers, only based my connection according to the layout.
I absolutely get your point, hovewer they dont show it and the current is not enough to kill it from the digital pins. Will always use resistor if from the 5V pin tho.
aight, guess I dont have that but they havent died from it in my circuit. Have had resistors to try to see where the issue could be but they just sink slightly in light. I guess it fair to say that they could brun out quicker by time.
they were 330 ohm, i tried both on all segments except the once not lit. Also tried to have them on the common cathodes, so pin 9-12. Didnt really help in any way I could see.
Except safer use of the components i guess as many are telling me haha.
This circuit shows how to correctly and safely wire a common anode 4x7 segment display for direct drive by an Arduino UNO R3. The resistors and the transistors are required.
