I have all of the four digits lighting up, but when I press the button, the led is bright in one end and spins in circles around the digit. I am trying to make it a stopwatch and I don't know how to fix it. Here is my code:
int d1 =2;
int d2 =3;
int d3 =4;
int d4 =5;
int a = 6;
int b = 7;
int c = 8;
int d = 9;
int e = 10;
int f = 11;
int g = 12;
int point = 13;
int button = A0;
boolean lastbutton=LOW;
boolean currentbutton=LOW;
boolean ledon=false;
long count1 = 0;
int x = 100;
int reset;
int count2=0;
pinMode(button, INPUT_PULLUP);
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(point, OUTPUT);
digitalWrite(d1, HIGH);
digitalWrite(d2, HIGH);
digitalWrite(d3, HIGH);
digitalWrite(d4, HIGH);
boolean debounce(boolean last){
boolean current=digitalRead(button);
if(last !=current){
delay(5);
return current;
currentbutton=debounce(lastbutton);
if(lastbutton==LOW && currentbutton==HIGH){
ledon=!ledon;
lastbutton=currentbutton;
if(ledon==false){
clearleds();
pickDigit(1);
pickNumber((count1/x/1000)%10);
delayMicroseconds(65);
clearleds();
pickDigit(2);
pickNumber((count1/x/100)%10);
clearleds();
pickDigit(3);
pickNumber((count1/x/10)%10);
clearleds();
pickDigit(4);
pickNumber(count1/x%10);
count1++;
if(ledon==true){
clearleds();
pickDigit(1);
clearleds();
pickDigit(2);
clearleds();
pickDigit(3);
clearleds();
pickDigit(4);
reset= digitalRead(button);
if(reset==LOW){
count2=count2+1;
else{
reset=HIGH;
count2=0;
if(count2==1000){
eight();
delay(100);
clearleds();
delay(100);
eight();
delay(100);
clearleds();
delay(800);
count2=0;
count1=0;
ledon=!ledon;
void pickDigit(int pick1)
digitalWrite(d1, LOW);
digitalWrite(d2, LOW);
digitalWrite(d3, LOW);
digitalWrite(d4, LOW);
switch(pick1)
case 1:
case 2:
case 3:
digitalWrite(point,LOW);
default:
digitalWrite(d4,HIGH);
void pickNumber(int pick2)
switch(pick2)
default:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9:
nine();
void clearleds()
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, HIGH);
digitalWrite(point, HIGH);
void zero()
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
void one(){
digitalWrite(a,HIGH);
digitalWrite(b,LOW);
digitalWrite(c,LOW);
digitalWrite(d,HIGH);
digitalWrite(e,HIGH);
digitalWrite(f,HIGH);
digitalWrite(g,HIGH);
void two(){
digitalWrite(a,LOW);
digitalWrite(c,HIGH);
digitalWrite(d,LOW);
digitalWrite(e,LOW);
digitalWrite(g,LOW);
void three(){
void four(){
digitalWrite(f,LOW);
void five(){
digitalWrite(b,HIGH);
void six(){
void seven(){
void eight(){
void nine(){
Any help is appreciated. Thank you!
(Code tags added by a Moderator. Please use the </> button on the menu next time. Thanks!)
