4 motor or 2 motor for line following robot ?
I decided to build a line following robot.
then i have two options
  1. two motor with caster wheel
  1. four motor line following robot
http://elcrost.com/wp-content/uploads/2016/10/project-lab-vex-robotics-microcontroller-roboticspla-based-projects-robotic-microcontrollers-for-manual-first-using-8051-pdf-ppt-tutorial.jpg
what is the best option for line follower.?
Generally, they use two motors - it is easier to make sharp turns with such a setup. Cheaper & easier to build too.
In theory best cornering speed needs good tyres and suspension, although this may not
be difficult to achieve on a smooth flat surface - soft enough tyres to act as shock absorber
is probably good enough. Castors have minimal grip, so I suspect a castor-free design can
outperform a two-wheel castor chassis on cornering. Its a common design because it is
simple to drive by dead-reckoning, can turn on the spot and doesn't need the complication
of a steering linkage, not because its the ultimate at speed.
4 wheels without a steering linkage means having to skid the tyres on tight turns, which
loses traction - only a design with a steering linkage like a larger vehicle is going to
be sure-footed I suspect.
