I have a rather simple Arduino circuit layout. Basically all of the wires go o pins on the board.
The only exception is that I have 3 to 4 wires that all need to go to ground and 3 to 4 wires that all need to go to 5V power. I'd prefer not to have to use a breadboard, circuit board, or screw cap connector.
Does there exist a 4 to one connector that I can plug 4 wires to on one side and it feeds out a single wire to connect to my (e.g. 5V) Arduino board?
DanMan1:
What are these wires powering? Do you know that these loads will not drag down the power supply?
DanMan1:
The only exception is that I have 3 to 4 wires that all need to go to ground and 3 to 4 wires that all need to go to 5V power. ** I'd prefer not to have to use a breadboard, circuit board, or screw cap connector.**
Are you building a permanent project, in which soldering the wires would be appropriate, or testing the project, in which case breadboard would be appropriate
What I do is use a piece of Copper Clad (PCB), cut it in a strip maybe 1" by 1/4", use my dremel tool cut a slot across the center, tape it down with double sided tape, or a hole and a screw, then I solder wires to each side, they are isolated if you removed the copper correctly. Here are some more suggestions: How to connect wires in 6 different ways This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
