433 Mhz RF Transmitter And Receiver Modules
Hello Geeks! :grinning:
I thought I would make an Arduino controlled Bait Boat using a 433Mhz RF Transmitter and Receiver Module pair. It's going well but I have two questions that I would like to ask if I may, one regarding the Transmitter sketch and one on the Receiver.
The RF driver is part of the RadioHead Library and the example I based the sketch on is from the excellent DroneBot Workshop (https://www.youtube.com/watch?v=b5C9SPVlU4U)
My version uses two joysticks with the intention of controlling two 9V DC motors on a model boat. The Arduino takes the output of the Joysticks and converts the readings to strings. An Output string concatenates the two with a comma separator and the RF Driver transmits the Output string using the 433 Mhz RF Transmitter.
The receiver code needs the received string to be a fixed length but the string varies from 2 x single character to 2 x four character as the Joysticks are moved.
So I added this code to include leading Xs where required:
 JoyStick1Val = analogRead (JoyStick1Pin);
  str_Zero = X;
  if (JoyStick1Val < 10)
    str_JoyStick1Val = str_Zero + str_Zero + str_Zero + JoyStick1Val;
The code works ok, in fact really well, it adds leading 0s instead of Xs and with the comma separator, I get a fixed 9 character Output string irrespective of the JoyStick read values. But I don't understand why it changes the X to a 0!
I'm guessing that the str_Zero = X; sees the word zero as a numerical string for some reason.
Does anyone have an explanation please?
Regards
Graeme
Code:
 *  The Bait Boat
 *  Rev 02.04 _Transmitter
 *  14/04/24
 *  Description
 *  Prototype to test the Transmitter/Receiver Pair
 *  Rev History
 *  Rev 02.01_Transmitter with text message string
 *  Rev 02.02_Transmitter - Transmitter with text message string
 *  Rev 02.02_Receiver - Receiver
 *  Rev 02.03_Transmitter - Transmitter with Joystick position string
 *  Rev 02.03_Receiver - Receiver
 *  Rev 02.04_Transmitter - Transmitter with Dual Joysticks and 2 x 4 character string
 *  Rev 02.04_Receiver - Receiver
//  Libraries
#include <RH_ASK.h>
#include <SPI.h>
//  Create RH Driver
RH_ASK rf_driver;
//  Variables
int DelayTime = 200;
int JoyStick1Pin = A1;
int JoyStick1Val;
int JoyStick2Pin = A2;
int JoyStick2Val;
int X;
String str_Zero;
String str_JoyStick1Val;
String str_JoyStick2Val;
String str_Output;
  rf_driver.init();   //  Arduino Pin 12
  Serial.begin (9600);
  pinMode(JoyStick1Pin, INPUT);
  pinMode(JoyStick2Pin, INPUT);
  //  Read Joystick 1 value
  str_Zero = X;
  //  Add 3 leading zeros to 1 character reading
  //  Add 2 leading zeros to 2 character reading
  if (JoyStick1Val >= 10 && JoyStick1Val < 100)
    str_JoyStick1Val = str_Zero + str_Zero + JoyStick1Val;
  //  Add 1 leading zero to 3 character reading
  if (JoyStick1Val >= 100 && JoyStick1Val < 1000)
    str_JoyStick1Val = str_Zero + JoyStick1Val;
    if (JoyStick1Val >= 1000)
    str_JoyStick1Val = JoyStick1Val;
  //  Read Joystick 2 value
  JoyStick2Val = analogRead (JoyStick2Pin);
   if (JoyStick2Val < 10)
    str_JoyStick2Val = str_Zero + str_Zero + str_Zero + JoyStick2Val;
  if (JoyStick2Val >= 10 && JoyStick2Val < 100)
    str_JoyStick2Val = str_Zero + str_Zero + JoyStick2Val;
  if (JoyStick2Val >= 100 && JoyStick2Val < 1000)
    str_JoyStick2Val = str_Zero + JoyStick2Val;
    if (JoyStick2Val >= 1000)
    str_JoyStick2Val = JoyStick2Val;
  //  Compose Output string
  str_Output = str_JoyStick1Val + "," + str_JoyStick2Val;
  //  Send 9 character string
  static char *msg = str_Output.c_str();
  rf_driver.send((uint8_t *)msg, strlen(msg));
  rf_driver.waitPacketSent();
  delay(DelayTime);
  Serial.println (str_Output);
//  EoF
A much simpler option is to send the variable(s) in binary, rather than a clumsy character string, or worse a String object that leads to program crashes.
For two joystick values something like this will work:
int joystick[2];
joystick[0] = analogRead(JoyStick1Pin);
joystick[1] = analogRead(JoyStick2Pin);
  rf_driver.send((uint8_t *)joystick, sizeof(joystick));
The receiver code is no more complex than that.
X is a global variable and is initialized to zero.
Cheers for the swift reply.
My second question was going to be about the receiver code crashing!
So I'll try your suggestion and see if the problem goes away and report back.
Thanks
Graeme
Understood.
Thanks.
Graeme
Well the Transmitter code works lovely, Serial.prints of both Joystick readings return a full range of 0 to 1023.
I'm struggling to get the Receiver code to work though. A Serial.print displays 248 for Joystick[0] and 1 for Joystick[1]. When I move the Joysticks I get non linear numbers displayed.
The maximum number displayed is 255 on Joystick 1. My guess is that it's because the results displayed for the Receiver array are 8 bit so unable to deal with the Joystick analogue 10 bit values.
The rf_driver library (Radiohead) needs to see a uint8_t variable to transmit a value. Is there an alternative way of transmitting 10 bit numbers using a uint8_t variable?
Thanks
Graeme
Post the code.
Integers of more than 8 bits are sent z using multiple 8 bit bytes. The receiver code should be easy if you examine how the r]tran sitter is sending.
a7
Here's the Receiver code I'm using:
 *  The Bait Boat
 *  Rev 02.05_Receiver - jremington
 *  21/04/24
 *  Graeme Durden
 *  Description
 *  Rev History
 *  Rev 02.05_Transmitter - jremington
//  Libraries
#include <RadioHead.h>
#include <RH_ASK.h>
#include <SPI.h>
//  Create RH Driver
RH_ASK rf_driver;
//  Variables
int JoyStick1Val;
int JoyStick2Val;
int JoyStick[2];
  rf_driver.init(); //  Arduino Pin 11
  uint8_t JoyStick[2];
  uint8_t JoySticklen = sizeof (JoyStick);
  if (rf_driver.recv(JoyStick, &JoySticklen))
    JoyStick1Val = JoyStick[0];
    JoyStick2Val = JoyStick[1];
  Serial.print (JoyStick[0]);
  Serial.print (" + ");
  Serial.println (JoyStick[1]);
  Serial.print(JoyStick1Val);
  Serial.print(" - ");
  Serial.println(JoyStick2Val);
  delay(DelayTime);
//  EoF
This in the sender
int joystick[2];
doesn't match what you say you want to receive
I'm just bluffing here, it's gonna be something more like
  int JoyStick[2];
  size_t JoySticklen = sizeof JoyStick / sizeof *JoyStick;
  if (rf_driver.recv((uint8_t *) JoyStick, &JoySticklen))
You send 4 bytes because you send 2 16 bit integers. You receive the same numbers and put them where they will mean the same thing.
a7
Looks like the RH_ASK doesn't have a function for that.
I got this when trying to compile:
g:\Arduino\Sketches\libraries\RadioHead/RH_ASK.h:305:39: note: candidate: virtual bool RH_ASK::recv(uint8_t*, uint8_t*)
RH_INTERRUPT_ATTR virtual bool recv(uint8_t* buf, uint8_t* len);
g:\Arduino\Sketches\libraries\RadioHead/RH_ASK.h:305:39: note: no known conversion for argument 2 from 'size_t* {aka unsigned int*}' to 'uint8_t* {aka unsigned char*}'
exit status 1
Compilation error: no matching function for call to 'RH_ASK::recv(uint8_t*, size_t*)'
Graeme
Fix that as follows:
  uint8_t JoySticklen = sizeof JoyStick;
You are the Man!
Thank you very much.
I'll post a picture of the first carp I catch!
Graeme
