48 stepper motor
https://arduino-info.wikispaces.com/SmallSteppers
I am trying to figure out why a stepper motor with a stepper rating of 48 but only has a true step ratting of 32.
grio:
Those numbers appear to be part of the motor "part number", not the number of steps per rotation.
Paul
" explain why the servo you have has a rating of 48 steps but the true steps are only 32."
I am trying to answer this.
I don't see why.... It seems like the datasheet says 48 steps too. I could just be over thinking it..
Maybe because it is defined in the code as a 32 step?
The other thing I am thinking is that the motor was just miss labeled and sold this way by china.
That dosn't change the physical movement of the motor, it just defines what the software "thinks" is one rotation.
Most of these motors(*) have non-integral gear ratios and are not an integer number of steps per revolution, note. They are made for moving car air-conditioning/heater air-flow vanes, I believe, so exact gear ratios
are of no consequence to the manufacturers. The gears are not designed for anything but light duty.
(*) I believe people have identified at least two versions.
There's another thread about them from a while ago: http://forum.arduino.cc/index.php?topic=71964.0
