I haw this code tor transmitter:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001"; //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
int button_pin = 2;
boolean button_state = 0;
pinMode(button_pin, INPUT);
radio.begin(); //Starting the Wireless communication
radio.openWritingPipe(address); //Setting the address where we will send the data
radio.setPALevel(RF24_PA_MIN); //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
radio.stopListening(); //This sets the module as transmitter
button_state = digitalRead(button_pin);
if(button_state == HIGH)
const char text[] = "Your Button State is HIGH";
radio.write(&text, sizeof(text)); //Sending the message to receiver
const char text[] = "Your Button State is LOW";
radio.write(&button_state, sizeof(button_state)); //Sending the message to receiver
and this code for receiver:
#include <SPI.h>
#include <RF24.h>
int led_pin = 3;
pinMode(6, OUTPUT);
radio.begin();
radio.openReadingPipe(0, address); //Setting the address at which we will receive the data
radio.setPALevel(RF24_PA_MIN); //You can set this as minimum or maximum depending on the distance between the transmitter and receiver.
radio.startListening(); //This sets the module as receiver
if (radio.available()) //Looking for the data.
char text[32] = ""; //Saving the incoming data
radio.read(&text, sizeof(text)); //Reading the data
radio.read(&button_state, sizeof(button_state)); //Reading the data
digitalWrite(6, HIGH);
Serial.println(text);
digitalWrite(6, LOW);
Serial.println(text);}
delay(5);
I need to expand to 4 channels, 2 day woking and solutions. Only this work.Schematisc is:
