50kg load cells with hx711 drifting problem
Hi!
I've never worked with load cells before but I got these load cells and the hx711 amplifier:
https://www.amazon.com/Half-bridge-Weighting-Sensor-Amplifier-Geekstory/dp/B079FTXR7Y/ref=sr_1_13?crid=3L6ZG2WCYDZ91&keywords=50+kg+load+cells+x711&qid=1689334087&sprefix=50+kg+load+cellshx71%2Caps%2C177&sr=8-13
and tried messing around with an arduino UNO to make a digital scale kind of device. I followed the following guide for connections.
Right now its all on a breadboard, but is connected correctly according to that guide. The problem I'm having is drifting of the values. Continuously up or down in quite a fast pace. I used the provided "calibration code" that is linked in the project that looks like the following:
   HX711_ADC
   Arduino library for HX711 24-Bit Analog-to-Digital Converter for Weight Scales
   Olav Kallhovd sept2017
   This example file shows how to calibrate the load cell and optionally store the calibration
   value in EEPROM, and also how to change the value manually.
   The result value can then later be included in your project sketch or fetched from EEPROM.
   To implement calibration in your project sketch the simplified procedure is as follow:
       LoadCell.tare();
       //place known mass
       LoadCell.refreshDataSet();
       float newCalibrationValue = LoadCell.getNewCalibration(known_mass);
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 4; //mcu > HX711 dout pin
const int HX711_sck = 5; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
  Serial.begin(57600); delay(10);
  Serial.println("Starting...");
  LoadCell.begin();
  //LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
  unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  LoadCell.start(stabilizingtime, _tare);
  if (LoadCell.getTareTimeoutFlag() || LoadCell.getSignalTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
    while (1);
  else {
    LoadCell.setCalFactor(1.0); // user set calibration value (float), initial value 1.0 may be used for this sketch
    Serial.println("Startup is complete");
  while (!LoadCell.update());
  calibrate(); //start calibration procedure
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check for new data/start next conversion:
  if (LoadCell.update()) newDataReady = true;
  // get smoothed value from the dataset:
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
      float i = LoadCell.getData();
      Serial.print("Load_cell output val: ");
      Serial.println(i);
      newDataReady = 0;
      t = millis();
  // receive command from serial terminal
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if (inByte == 't') LoadCell.tareNoDelay(); //tare
    else if (inByte == 'r') calibrate(); //calibrate
    else if (inByte == 'c') changeSavedCalFactor(); //edit calibration value manually
  // check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
void calibrate() {
  Serial.println("***");
  Serial.println("Start calibration:");
  Serial.println("Place the load cell an a level stable surface.");
  Serial.println("Remove any load applied to the load cell.");
  Serial.println("Send 't' from serial monitor to set the tare offset.");
  boolean _resume = false;
  while (_resume == false) {
    LoadCell.update();
      _resume = true;
  Serial.println("Now, place your known mass on the loadcell.");
  Serial.println("Then send the weight of this mass (i.e. 100.0) from serial monitor.");
  float known_mass = 0;
  _resume = false;
    LoadCell.update();
      known_mass = Serial.parseFloat();
      if (known_mass != 0) {
        Serial.print("Known mass is: ");
        Serial.println(known_mass);
        _resume = true;
  LoadCell.refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
  float newCalibrationValue = LoadCell.getNewCalibration(known_mass); //get the new calibration value
  Serial.print("New calibration value has been set to: ");
  Serial.print(newCalibrationValue);
  Serial.println(", use this as calibration value (calFactor) in your project sketch.");
  Serial.print("Save this value to EEPROM adress ");
  Serial.print(calVal_eepromAdress);
  Serial.println("? y/n");
  _resume = false;
      if (inByte == 'y') {
        EEPROM.begin(512);
#endif
        EEPROM.put(calVal_eepromAdress, newCalibrationValue);
        EEPROM.commit();
#endif
        EEPROM.get(calVal_eepromAdress, newCalibrationValue);
        Serial.print("Value ");
        Serial.print(" saved to EEPROM address: ");
        Serial.println(calVal_eepromAdress);
        _resume = true;
      else if (inByte == 'n') {
        Serial.println("Value not saved to EEPROM");
        _resume = true;
  Serial.println("End calibration");
  Serial.println("To re-calibrate, send 'r' from serial monitor.");
  Serial.println("For manual edit of the calibration value, send 'c' from serial monitor.");
void changeSavedCalFactor() {
  float oldCalibrationValue = LoadCell.getCalFactor();
  Serial.print("Current value is: ");
  Serial.println(oldCalibrationValue);
  Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
  float newCalibrationValue;
      newCalibrationValue = Serial.parseFloat();
      if (newCalibrationValue != 0) {
        Serial.print("New calibration value is: ");
        Serial.println(newCalibrationValue);
        LoadCell.setCalFactor(newCalibrationValue);
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
  Serial.println("End change calibration value");
But the result I'm getting is just drifting of the weights. I've tried to tare with loads of about 10kg just to make sure its not that the loads are unstable when nothing is on them but it does not seem to help. I can put an object on and and the monitor will read higher and higher/ lower and lower values every time the program reads. An example of the serial monitor:
I've checked on other topics with similar problems but have not gotten wiser. I've checked the voltage between E+ and E- and the multimeter says open loop. The voltage between A+ and A- is practically 0. I've heard that some HX711 have a missing ground plate and that E+ is then not connected to ground which it should be, but I don't know if that's the case for me. And if it is, how should i add a resistor to fix that?
Does anybody know what is happening? I hope I've provided enough background information.
You can use a decoupling capacitors between the power supply and the components to filter out noise. Additionally, keep the load cell wiring away from any sources of electromagnetic interference
Hi!
Thank you for the answer. I added a 100 uF decoupling capacitor on the HX711 and it seems to be doing some good. At least when i tested it during a shorter period of time. The weight fluctuates with about +50g if I added a weight of 219g. but seems to stay, at least now, within 212-265 and move rather quickly between those values. I'm guessing that could be a rather normal amount to fluctuate between. I can't add any other decoupling capacitors on any other part of the circuit, I'm guessing?
Make sure all the components in your circuit have a common ground reference. Connect the ground (GND) of the Arduino, HX711, and load cells together. Proper grounding is essential to avoid noise and unstable readings. 1. The HX711 has an adjustable data rate. Make sure the sampling rate is appropriate for your application. You can experiment with different data rates to see if it affects the stability of the readings.
If you are still experiencing fluctuations, you can try implementing additional digital filtering techniques in your code. Techniques like moving averages or exponential moving averages can help smooth out the readings. Adding more capacitors may not significantly improve the performance further.
Will try. Thank you again!
