5A Buck converter
The underside of a buck converter I have
https://www.ebay.com/itm/DC-DC-Adjustable-Buck-Step-down-Converter-Voltage-Module-4V-38V-to-1-25V-36V-New/332923880412?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
has 5 solder points labeled:
VCC
RST
SWIM
RXD
GND
How are these connections used?
duinoMike:
Link does not work .
Post the name of the module or the name of the IC.
DC-DC Adjustable Buck Step down Converter Voltage Module 4V-38V to 1.25V-36V
Link works for me. I only see an IN+, IN-, OUT+ and OUT- on those photos. No other solder points or markings.
OP do go and read your own question imagining you now NOTHING at all about the module in question. Do you think you would have any chance of giving an informed answer?
Now think of what information could possibly be of use to answer this question, and post it. All of it, and the rest as well.
And do remember to derate such cheap no-brand modules generously.
I stated that the solder points are on the underside of the module. They are not visible from the top.
The question is directed at someone who may have worked with a similar module that takes data input.
With practically no details of the module there's nothing to tell.
It has some chip we can't identify and has some markings we can't see because that website doesn't show them
and you haven't posted a picture.
Currently you are the only one in a position to begin to answer the question...
duinoMike:
When something is "similar" it is not relevant - it may work the same way, it may work in a totally different way. We need to know which exact one.
Why do you care?
I'm hoping they are for digital control of the module.
Here is a pic of the underside of the module. Hope this helps.
I took off the pot. May replace with digital pot. Still would like to know what the connections are for.
Information about those pinouts may or may not be in the mystery chip data sheet.
Well that's clearly nothing like the module pictured in the link you posted originally - perhaps a picture of the front as well would be in order? Any part numbers on the chips too, often they are illegible in photos.
Rather than wait for us to ask for details, please post all the details up front, its much more productive.
My guess is, from searching for that SKU number, this is a converter with a display, and the microcontroller driving the display has some pins pulled out for programming purposes.
My apologies, I posted the wrong link.
This is the buck in question.
The unit on the website does not have the solder connections on the bottom that I have otherwise its identical.
https://www.amazon.com/gp/product/B00VWL41TM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It would be a stretch to call the bottom views of the two boards (replies #8 and #11) "similar".
duinoMike:
Doesn't match the photo you posted before.
Why don't you tell us what you REALLY have and stop wasting our time? Starting by the question posted a few times before: what's the actual number printed on the main chip?
