I'm scowering the interwebs looking for a 5v signal 12v operating stdp relay board for running 12v ballvalves off a 5v signal. operating amps of the ball valve is 1.2mA. I'm still learning, so i'm sticking with prebuilt boards, as i'm learning more coding than electronics theory right now. Any help on locating something like this would be greatly appreciated.
No. I bought the 5 volt version of the relay. That means that the coil in the relay runs from 5 volt. As I use USB power I feed the relay from the 5 volt pin on the UNO. The signal for activating the relay connects directly to the UNO.
I did measure the current consumtion of the coil and it's very low. If You want I can measure again and tell You.
