Hi, i finished the code for transmitter 1 and 2 to test if the NodeMCU can receive more than 1 transmitter but it still receives from 1 transmitter (00002). what can I do to fix this?
Transmitter 1 code (Arduino Nano)
///-----------------------------------EFL CODE - TRANSMITTER 1-------------------------------///
#include <DHT.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(0, 10); // CE, CSN
const byte pipe1[6] = "00001";
const int relayPin1 = 3; // Pin for relay 1
const int relayPin2 = 4; // Pin for relay 2
const int relayPin3 = 7; // Pin for relay 3
const int relayPin4 = 8; // Pin for relay 4
const int relayPump = 2; // Pin for relay 5
const int flowPin = 5; // Pin for Flow meter
const int thPin = 6; // Pin for Temp and Humidity
const int moisturePin1 = A4; // Pin for moisture sensor 1
const int moisturePin2 = A3; // Pin for moisture sensor 2
const int moisturePin3 = A2; // Pin for moisture sensor 3
const int moisturePin4 = A1; // Pin for moisture sensor 4
const int phPin = A6;
const int tbdPin = A7;
//const float thresholdResistance = 1.0; // Threshold resistance in ohms
const float lowerThreshold = 0.9; // Lower threshold in ohms
const float upperThreshold = 1.5; // Upper threshold in ohms
const long interval = 2000; // Reading interval in milliseconds (5 seconds)
unsigned long currentTime;
unsigned long lastTime;
unsigned long pulse_freq;
double flow;
long previousMillis = 0;
DHT dht(thPin, DHT11);
struct SensorData {
float sensor1;
float sensor2;
float sensor3;
float sensor4;
float temperature;
float humidity;
float pHValue;
float flow;
byte transmitterId;
SensorData node1data;
void pulse () // Interrupt function
pulse_freq++;
Serial.begin(9600); // Initialize serial communication
radio.begin();
radio.openWritingPipe(pipe1); // Set the address for writing data
radio.setPALevel(RF24_PA_MAX);
radio.stopListening();
// Set relay pins as OUTPUT and turn off relays initially (active HIGH)
pinMode(relayPin1, OUTPUT);
pinMode(relayPin2, OUTPUT);
pinMode(relayPin3, OUTPUT);
pinMode(relayPin4, OUTPUT);
pinMode(relayPump, OUTPUT);
pinMode(flowPin, INPUT);
pinMode(thPin, INPUT);
digitalWrite(relayPin1, HIGH);
digitalWrite(relayPin2, HIGH);
digitalWrite(relayPin3, HIGH);
digitalWrite(relayPin4, HIGH);
digitalWrite(relayPump, HIGH);
digitalWrite(flowPin, HIGH);
digitalWrite(thPin, HIGH);
dht.begin();
attachInterrupt(0, pulse, RISING); // Setup Interrupt
byte transmitterId = 1;
int relay1Status = digitalRead(relayPin1);
int relay2Status = digitalRead(relayPin2);
int relay3Status = digitalRead(relayPin3);
int relay4Status = digitalRead(relayPin4);
int pumpStatus = digitalRead(relayPump);
// Read temperature and humidity from DHT sensor
float humidity = dht.readHumidity();
float temperature = dht.readTemperature();
int rawValue = analogRead(phPin);
float pHValue = map(rawValue, 0, 1023, 0, 14);
float resistance1 = calculateResistance(analogRead(moisturePin1));
float resistance2 = calculateResistance(analogRead(moisturePin2));
float resistance3 = calculateResistance(analogRead(moisturePin3));
float resistance4 = calculateResistance(analogRead(moisturePin4));
int sensorValue1 = analogRead(moisturePin1);
int sensorValue2 = analogRead(moisturePin2);
int sensorValue3 = analogRead(moisturePin3);
int sensorValue4 = analogRead(moisturePin4);
float voltage1 = sensorValue1 * (5.0 / 1023.0);
float voltage2 = sensorValue2 * (5.0 / 1023.0);
float voltage3 = sensorValue3 * (5.0 / 1023.0);
float voltage4 = sensorValue4 * (5.0 / 1023.0);
// Every second, calculate and print L/Min
if(currentMillis >= (lastTime + 1000)){
lastTime = currentMillis;
// Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
flow = (pulse_freq / 7.5);
pulse_freq = 0; // Reset Counter
if (currentMillis - previousMillis >= interval) {
Serial.println("Transmitter ID: " + String(transmitterId));
printResistance("Sensor 1", resistance1, voltage1, sensorValue1);
printResistance("Sensor 2", resistance2, voltage2, sensorValue2);
printResistance("Sensor 3", resistance3, voltage3, sensorValue3);
printResistance("Sensor 4", resistance4, voltage4, sensorValue4);
Serial.print(flow);
Serial.println(" L/Min");
if (!isnan(humidity) && !isnan(temperature)) {
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println("%\t");
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println("°C");
Serial.println("Failed to read from DHT sensor!");
// Print pH value to Serial Monitor
Serial.print("pH Value: ");
Serial.println(pHValue);
Serial.print("Relay 1 Status: ");
Serial.println(relay1Status == LOW ? "ON" : "OFF");
Serial.print("Relay 2 Status: ");
Serial.println(relay2Status == LOW ? "ON" : "OFF");
Serial.print("Relay 3 Status: ");
Serial.println(relay3Status == LOW ? "ON" : "OFF");
Serial.print("Relay 4 Status: ");
Serial.println(relay4Status == LOW ? "ON" : "OFF");
Serial.print("Pump Status: ");
Serial.println(pumpStatus == LOW ? "ON" : "OFF");
if (resistance1 < lowerThreshold) {
digitalWrite(relayPin1, LOW);
} else if (resistance1 > upperThreshold) {
if (resistance2 < lowerThreshold) {
digitalWrite(relayPin2, LOW);
} else if (resistance2 > upperThreshold) {
if (resistance3 < lowerThreshold) {
digitalWrite(relayPin3, LOW);
} else if (resistance3 > upperThreshold) {
if (resistance4 < lowerThreshold) {
digitalWrite(relayPin4, LOW);
} else if (resistance4 > upperThreshold) {
// Check if any of the 4 relays are on
if (relay1Status == LOW || relay2Status == LOW || relay3Status == LOW || relay4Status == LOW) {
// Turn on the 5th relay
digitalWrite(relayPump, LOW);
// Turn off the 5th relay
delay(2000);
node1data.sensor1 = sensorValue1;
node1data.sensor2 = sensorValue2;
node1data.sensor3 = sensorValue3;
node1data.sensor4 = sensorValue4;
node1data.temperature = temperature;
node1data.humidity = humidity;
node1data.pHValue = pHValue;
node1data.transmitterId = transmitterId;
// Send data to receiver
radio.write(&node1data, sizeof(node1data));
// Function to calculate resistance based on analog value
float calculateResistance(int sensorValue) {
float voltage = sensorValue * (5.0 / 1023.0);
return (5.0 - voltage) / voltage;
// Function to print resistance values
void printResistance(const char* sensorName, float resistance, float voltage, int sensorValue) {
Serial.print(sensorName);
Serial.print(" Resistance: ");
Serial.print(resistance, 2);
Serial.print(" ohms, Voltage: ");
Serial.print(voltage, 2);
Serial.print(" V, Sensor Value: ");
Serial.println(sensorValue);
Transmitter 2 code (Arduino Nano)
///-----------------------------------EFL CODE - TRANSMITTER 2-------------------------------///
#include <DHT.h>
#include <SPI.h>
#include <RF24.h>
const byte pipe2[6] = "00002";
double flow;
struct SensorData {
float sensor1;
float sensor2;
float sensor3;
float sensor4;
float temperature;
float humidity;
float pHValue;
float flow;
byte transmitterId;
SensorData node2data;
pulse_freq++;
radio.begin();
radio.openWritingPipe(pipe2); // Set the address for writing data
dht.begin();
byte transmitterId = 2;
Serial.print(flow);
delay(2000);
node2data.sensor1 = sensorValue1;
node2data.sensor2 = sensorValue2;
node2data.sensor3 = sensorValue3;
node2data.sensor4 = sensorValue4;
node2data.temperature = temperature;
node2data.humidity = humidity;
node2data.pHValue = pHValue;
node2data.transmitterId = transmitterId;
radio.write(&node2data, sizeof(node2data));
Receiver code (NodeMCU)
#include <SPI.h>
#include <RF24.h>
const float lowerThreshold = 0.4; // Lower threshold in ohms
float percent1 = 0;
float percent2 = 0;
float percent3 = 0;
float percent4 = 0;
float resistance1 = 0;
float resistance2 = 0;
float resistance3 = 0;
float resistance4 = 0;
float voltage1 = 0;
float voltage2 = 0;
float voltage3 = 0;
float voltage4 = 0;
float sensorValue1 = 0;
float sensorValue2 = 0;
float sensorValue3 = 0;
float sensorValue4 = 0;
float relay1 = 0;
float relay2 = 0;
float relay3 = 0;
float relay4 = 0;
float pump = 0;
RF24 radio(D4, D2);
const byte addresses [][6] = {"00001", "00002"};
struct SensorData {
float sensor1;
float sensor2;
float sensor3;
float sensor4;
float temperature;
float humidity;
float pHValue;
float flow;
SensorData receivedData;
radio.begin();
radio.openReadingPipe(0, addresses[0]); // Set up the first reading pipe for "00001"
radio.openReadingPipe(1, addresses[1]); // Set up the second reading pipe for "00002"
radio.startListening();
while (radio.available()) {
radio.read(&receivedData, sizeof(receivedData));
Serial.println("Received data from Arduino Nano 1:");
Serial.print("sensor 1: ");
Serial.println(receivedData.sensor1, 2);
Serial.print("sensor 2: ");
Serial.println(receivedData.sensor2, 2);
Serial.print("sensor 3: ");
Serial.println(receivedData.sensor3, 2);
Serial.print("sensor 4: ");
Serial.println(receivedData.sensor4, 2);
Serial.print(receivedData.temperature);
Serial.print(receivedData.humidity);
Serial.println(receivedData.pHValue);
sensorValue1 = receivedData.sensor1;
sensorValue2 = receivedData.sensor2;
sensorValue3 = receivedData.sensor3;
sensorValue4 = receivedData.sensor4;
resistance1 = calculateResistance(sensorValue1);
resistance2 = calculateResistance(sensorValue2);
resistance3 = calculateResistance(sensorValue3);
resistance4 = calculateResistance(sensorValue4);
if (sensorValue1 !=0){
percent1 = (voltage1/5) * 100;
if (sensorValue2 !=0){
percent2 = (voltage2/5) * 100;
if (sensorValue3 !=0){
percent3 = (voltage3/5) * 100;
if (sensorValue4 !=0){
percent4 = (voltage4/5) * 100;
printResistance("Sensor 1", resistance1, voltage1, percent1);
printResistance("Sensor 2", resistance2, voltage2, percent2);
printResistance("Sensor 3", resistance3, voltage3, percent3);
printResistance("Sensor 4", resistance4, voltage4, percent4);
