Wireless data exchange between two arduinos using NRF24L01
Good luck guys. I have an Arduino project that I use. It includes sensors (voltage/temperature and fan control) and LCD Keypad Shield. I want to add NRF24L01 to my project to be able to transfer data wirelessly without changing the original code and without experiencing pin conflicts. The Arduino that the sensors I am currently using are connected to will be the master and transmitter. Apart from the receiver, I want to see the values ​​coming from the transmitter on the LCD keypad shield screen with an Arduino. I would be very happy if you could help me. I am sharing the original code with you. I have two Arduino Uno, two LCD keypad shields and two NRF24L01 modules.
// PA-Monitor-SG-Lab-2GHz4-V2.ino   ---------- c 2020 by DC5ZM -------------------------------------------------------
// PCB for UNO and NANO are available by weber.r1@t-online.de
// ---------------------------------------------- include libraries --------------------------------------------------
#include <OneWire.h>
#include <DallasTemperature.h>
#include <LiquidCrystal.h>
// ---------------------------------------------- define constants ---------------------------------------------------
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);  //allocate uno pins to LCD diplay pins(rs,enable,DB4,DB5,DB6,DB7)
#define ONE_WIRE_BUS 12  //  Data wire is plugged into pin 12 on the Arduino
#define TEMPERATURE_PRECISION 13
#define FAN_PIN 11
#define NO 0
#define YES 1
// ************************************************************** variables to be changed for calibration *********
// use   http://www.xuru.org/rt/PR.asp#CopyPaste   for calculation coefficients                                   *        *
//        formula used:   y = a +b*x + c*x*x   *
float a_drv = -0.087, b_drv = 13.615, c_drv = 61.081;            // coefficients of polygon approximation DRV *
float a_fwd = 0.491, b_fwd = -1.099, c_fwd = 1.661;             //                                   ... FWD *
float a_ref = 0.491, b_ref = -1.099, c_ref = 1.661;             //                                   ... REF *
float scc_drv = 1.0, scc_fwd = 1.0, scc_ref = 1.0;              // Shift_Calibration_Curve 0.93=7%> 1.07=7%< *
float power_drv_min = 1;                                        // minimal power for calculation and display *
byte power_fwd_min = 1, power_ref_min = 1, power_drv_max = 50;  // min. power for calc. and display          *
byte temp_fan_on = 45, voltmeter_full_scale = 30;               // fan on at overtemperature, adjust att. R1 *
unsigned long time;
uint16_t temp_integer;  // uint16_t = 16 bit integer
char temp_string[8], power_fwd_string[8], power_ref_string[8], power_drv_string[8], swr_string[8];
char pa_voltage_string[8], temp_fan_on_string[8];
float reflexion_coefficient, swr, power_fwd, power_ref, power_drv, voltage_fwd, voltage_ref, voltage_drv;
float voltage_fwd_peak = 0, voltage_ref_peak = 0, voltage_drv_peak = 0;
float temperature, tmp_old = 0, pa_voltage;
byte temp_byte, temp_bar_max = 100, power_drv_int, iii = 0;
byte menu = 1, temp_fan_on_marker;
boolean fwd_too_low = NO, ref_too_low = NO, fan_active = NO, error_fwd = NO, error_ref = NO, error_swr = NO;
OneWire oneWire(ONE_WIRE_BUS);        // Setup a oneWire instance to communicate with any OneWire devices
DallasTemperature sensors(&oneWire);  // Pass oneWire reference to Dallas Temperature
void setup(void) {
  lcd.begin(16, 2);  // display with 16 colum and 2 lines
  sensors.begin();   // Start up the library
  pinMode(FAN_PIN, OUTPUT);
  read_temperature();
  lcd.print("PA M O N I T O R");
  lcd.setCursor(0, 1);  // colum, line nr.
  lcd.print("TR 2024 ");
  lcd.print("by ");
  lcd.print("TA4DC");
  delay(1500);
  lcd.clear();
void loop(void) {
  select_menu();
  read_temperature();
void select_menu() {
  if (analogRead(A0) < 1000) menu++;  // if any of 5 keys pressed change menu
  while (analogRead(A0) < 1000)
    ;  // wait for key released
  if (menu > 3) menu = 1;
  if (menu == 1) menu_directional_couplers();
  if (menu == 2) menu_temperature();
  if (menu == 3) menu_supply_fan();
void menu_directional_couplers() {
  for (iii = 0; iii < 20; iii++)  // Take 20 samples and save the highest value
    voltage_fwd = analogRead(A1);
    voltage_ref = analogRead(A2);
    voltage_drv = analogRead(A3);
    if (voltage_fwd > voltage_fwd_peak) voltage_fwd_peak = voltage_fwd;  // safe the peak of 10 measurements
    if (voltage_ref > voltage_ref_peak) voltage_ref_peak = voltage_ref;
    if (voltage_drv > voltage_drv_peak) voltage_drv_peak = voltage_drv;
  voltage_fwd = voltage_fwd_peak;  // use peak voltage for processing
  voltage_ref = voltage_ref_peak;
  voltage_drv = voltage_drv_peak;
  // ---------------------------------------- calculate coupler values -------------------------------------------------
  voltage_fwd = voltage_fwd * 5 / 1023 * scc_fwd;  // normalize measured value FWD to 5V x scc_fwd
  voltage_ref = voltage_ref * 5 / 1023 * scc_ref;  // ... REF to 5V x scc_ref
  voltage_drv = voltage_drv * 5 / 1023 * scc_drv;  //...  DRV to 5V x scc_drv
  power_fwd = a_fwd + b_fwd * voltage_fwd + c_fwd * voltage_fwd * voltage_fwd;  // polygon approximatiion equation fwd
  if (power_fwd < 0) power_fwd = 0;                                             // avoid negativ values
  power_ref = a_ref + b_ref * voltage_ref + c_ref * voltage_ref * voltage_ref;  // polygon approximatiion equation ref
  if (power_ref < 0) power_ref = 0;
  power_drv = a_drv + b_drv * voltage_drv + c_drv * voltage_drv * voltage_drv;  // polygon approximatiion equation drv
  if (power_drv < 0) power_drv = 0;
  if (power_fwd < power_fwd_min) error_fwd = YES;  // check for errors
  else error_fwd = NO;
  if (power_ref < power_ref_min) error_ref = YES;
  else error_ref = NO;
  if ((power_fwd <= power_ref) || (error_fwd == YES) || (error_ref == YES)) error_swr = YES;
  else error_swr = NO;
  display_coupler_values();
  voltage_fwd_peak = 0;  // set peak voltages back to 0
  voltage_ref_peak = 0;
void display_coupler_values() {
  lcd.setCursor(0, 0);
  lcd.print("FWD   W  REF   W");
  lcd.setCursor(4, 0);
  if (error_fwd == NO) {
    dtostrf(power_fwd, 2, 0, power_fwd_string);  //  variable for converting float type numbers
    lcd.print(power_fwd_string);
    lcd.print("<");
    lcd.print(power_fwd_min);
  lcd.setCursor(13, 0);
  if (error_ref == NO) {
    dtostrf(power_ref, 2, 0, power_ref_string);  //  variable for converting float type numbers
    lcd.print(power_ref_string);
    lcd.print("<");
    lcd.print(power_ref_min);
  // ....................................................  line 2 of lcd display  ......................................
  lcd.print("DRV   mW SWR    ");
  lcd.setCursor(4, 1);
  if ((power_drv < power_drv_max) && (power_drv >= power_drv_min)) {
    dtostrf(power_drv, 2, 0, power_drv_string);  //  variable for converting float type numbers
    lcd.print(power_drv_string);
    lcd.setCursor(2, 1);
    lcd.print("V");
  if (power_drv < power_drv_min) {
    lcd.setCursor(5, 1);
    lcd.print(power_drv_min);
    lcd.print("<");
    lcd.setCursor(6, 1);
    lcd.print("mW ");
  if (power_drv >= power_drv_max) {
    lcd.print(power_drv_max);
    lcd.setCursor(3, 1);
    lcd.print(">");
  if (error_swr == NO) {
    lcd.setCursor(13, 1);
      reflexion_coefficient = sqrt(power_ref / power_fwd);  // calculate SWR
      if (reflexion_coefficient <= 0.8) {
        swr = (1 + reflexion_coefficient) / (1 - reflexion_coefficient);
        dtostrf(swr, 2, 1, swr_string);
        lcd.print(swr_string);  // display SWR
      } else lcd.print(">10");  // SWR too high
  } else  // display PA temperature
    dtostrf(temperature, 2, 0, temp_string);
    lcd.setCursor(9, 1);
    lcd.print("TMP   \xDF");
    lcd.print(temp_string);
    if (fan_active == YES) {
      lcd.setCursor(15, 1);
      delay(150);
      lcd.print(" ");
      delay(150);
  delay(200);
void menu_temperature() {
  dtostrf(temperature, 4, 1, temp_string);  //  variable for converting float type numbers
  lcd.setCursor(0, 0);                      // colum, line nr.
  lcd.print("PA TEMP.: ");
  lcd.print("\xDF");  // character sign °
  lcd.print("C");
  lcd.print("0____________100");
  lcd.setCursor(1, 1);
  if (temperature < 0) temperature = 0;
  if (temperature > 100) temperature = 100;
  temp_byte = temperature;
  temp_byte /= 7.14;                                         // 0 to 100 normalized to0 bis 14
  for (iii = 0; iii <= temp_byte; iii++) lcd.print("\xFF");  // \xFF = special character black rectangle
    lcd.setCursor(14, 0);
    delay(150);
    lcd.print(" ");
    delay(150);
  delay(250);  // delay prevents flickering of the display
void menu_supply_fan()
  pa_voltage = 0;
  for (iii = 0; iii < 10; iii++)
    pa_voltage = pa_voltage + analogRead(A4);
  pa_voltage /= 9;                                        // average of 10 measurements
  pa_voltage = pa_voltage * voltmeter_full_scale / 1023;  // adjust R1 when changing voltmeter_full_scale
  lcd.print("PWR SUPPLY     V");
  lcd.setCursor(11, 0);
  dtostrf(pa_voltage, 3, 1, pa_voltage_string);  //  variable for converting float type numbers
  lcd.print(pa_voltage_string);
  // ..........................................  line 2 of lcd display  ................................................
  lcd.print("FAN ON TMP >");
  dtostrf(temp_fan_on, 2, 0, temp_fan_on_string);  //  variable for converting float type numbers to strings
  lcd.print(temp_fan_on_string);
  lcd.print("\xDF");
  lcd.print("C");
    delay(300);
    lcd.print("  ");
    delay(300);
  }  // flash word "ON"
void read_temperature() {
  if ((millis() - time) > 5000)  // The sensor is only read out every 5s
    sensors.requestTemperatures();             // because the process takes 750ms
    temperature = sensors.getTempCByIndex(0);  // in high resolution mode.
    time = millis();
  if (temperature >= temp_fan_on) {
    digitalWrite(FAN_PIN, HIGH);
    fan_active = YES;
    digitalWrite(FAN_PIN, LOW);
    fan_active = NO;
So do you have a question?
Have you worked through the examples in the RF24 Library or perhaps the Robin2 Tutorial?
Could you share the wiring diagram?
I want to add NRF24L01 to this code and have it transfer data wirelessly to another Arduino. In other words, I want to see the information on the LCD screen that works with the original code I shared wirelessly on another Arduino screen. The sensors will be connected to the main Arduino. But I will see the information on both the main Arduino and the other Arduino screen wirelessly.
That's what you said in your first post. Did you do this?
I couldn't do it. I don't have any knowledge about coding. I need help. I want to add to the original code and use it as a transmitter. and I want to run another orduino with a receiver code.
Can I transfer the information in this project wirelessly to another Arduino screen?
That's why there's example code. Follow Robin2's Tutorial.
First, use the tutorial and example code to learn how to do a simple data transfer. Then, incorporate that into your existing code. Folks on the forum will help you, but not do it for you. You must put in the effort.
