I havent really started coding it yet. its my first time using an arduino so im not sure how to code a timer for it. i know how to make a timer and i know C code im just having difficulty bridging the two. The following Code is code i have for a countdown from 9 to 0, but im not sure how to get it to 60 and i dont want it to loop. but i can only seem to get it to work in a loop
// Define the LED digit patters, from 0 - 9
// Note that these patterns are for common cathode displays
// For common anode displays, change the 1's to 0's and 0's to 1's
// 1 = LED on, 0 = LED off, in this order:
// Arduino pin: 2,3,4,5,6,7,8
byte seven_seg_digits[10][7] = {
0,0,0,0,0,0,1 }
, // = 0
1,0,0,1,1,1,1 }
, // = 1
0,0,1,0,0,1,0 }
, // = 2
0,0,0,0,1,1,0 }
, // = 3
1,0,0,1,1,0,0 }
, // = 4
0,1,0,0,1,0,0 }
, // = 5
0,1,0,0,0,0,0 }
, // = 6
0,0,0,1,1,1,1 }
, // = 7
0,0,0,0,0,0,0 }
, // = 8
0,0,0,1,1,0,0,0,1,1 } // = 9
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
writeDot(0); // start with the "dot" off
void writeDot(byte dot) {
digitalWrite(9, dot);
void sevenSegWrite(byte digit) {
byte pin = 2;
for (byte segCount = 0; segCount < 7; ++segCount) {
digitalWrite(pin, seven_seg_digits[digit][segCount]);
++pin;
for (byte count = 10; count > 0; --count) {
sevenSegWrite(count - 1);
delay(4000);
