644 Sanguino digital pin problem
I need more digital pins and memory for a standalone project on pcb.
I'm passed from 328 to 644p aka sanguino.
I have successfully burned the bootloader and I have adapted my old code to fit the new microcontroller.
I use port manipulation and have some trouble with C port.
Pin 24, 25, 26 and 27 ( PC2 to PC5 or D18 to 21 ) don't work.
At a quick check they are always at +5 but with a minimal current drain that can't turn on a led ( you can just notice a weak light on the cathode if you cover it with a hand ).
Today I have made a test sketch to check every digital out:
  for ( int i=0; i<32; i++){
   pinMode(i, OUTPUT);
   digitalWrite(i, HIGH);
   digitalWrite(i, LOW);
I have the same problem. :slightly_frowning_face:
I'm wondering if these pins have a different setup and i'm missing something in my code that's not needed with other atmega.
Can you help me?
Probably just a problem with mappings in pins_arduino.h
This is from C:\Program Files (x86)\Arduino\hardware\sanguino\variants\standard\pins_arduino.h but it's pretty complicated for me.
  pins_arduino.h - Pin definition functions for Arduino
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2007 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
  $Id: wiring.h 249 2007-02-03 16:52:51Z mellis $
  Changelog
  11/25/11  - ryan@ryanmsutton.com - Add pins for Sanguino 644P and 1284P
  07/15/12  - ryan@ryanmsutton.com - Updated for arduino0101
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
#define NOT_A_PIN 0
#define NOT_A_PORT 0
#define NOT_ON_TIMER 0
#define TIMER0A 1
#define TIMER0B 2
#define TIMER1A 3
#define TIMER1B 4
#define TIMER2  5
#define TIMER2A 6
#define TIMER2B 7
#define TIMER3A 8
#define TIMER3B 9
#define TIMER3C 10
#define TIMER4A 11
#define TIMER4B 12
#define TIMER4C 13
#define TIMER5A 14
#define TIMER5B 15
#define TIMER5C 16
const static uint8_t SS   = 4;
const static uint8_t MOSI = 5;
const static uint8_t MISO = 6;
const static uint8_t SCK  = 7;
static const uint8_t SDA = 17;
static const uint8_t SCL = 16;
static const uint8_t LED_BUILTIN = 13;
static const uint8_t A0 = 31;
static const uint8_t A1 = 30;
static const uint8_t A2 = 29;
static const uint8_t A3 = 28;
static const uint8_t A4 = 27;
static const uint8_t A5 = 26;
static const uint8_t A6 = 25;
static const uint8_t A7 = 24;
// On the ATmega1280, the addresses of some of the port registers are
// greater than 255, so we can't store them in uint8_t's.
// extern const uint16_t PROGMEM port_to_mode_PGM[];
// extern const uint16_t PROGMEM port_to_input_PGM[];
// extern const uint16_t PROGMEM port_to_output_PGM[];
// extern const uint8_t PROGMEM digital_pin_to_port_PGM[];
// extern const uint8_t PROGMEM digital_pin_to_bit_PGM[];
// extern const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[];
// extern const uint8_t PROGMEM digital_pin_to_timer_PGM[];
// ATMEL ATMEGA644P / SANGUINO
//  INT0 (D 0) PB0  1|        |40  PA0 (AI 0 / D31)
//  INT1 (D 1) PB1  2|        |39  PA1 (AI 1 / D30)
//  INT2 (D 2) PB2  3|        |38  PA2 (AI 2 / D29)
//   PWM (D 3) PB3  4|        |37  PA3 (AI 3 / D28)
//   PWM (D 4) PB4  5|        |36  PA4 (AI 4 / D27)
//  MOSI (D 5) PB5  6|        |35  PA5 (AI 5 / D26)
//  MISO (D 6) PB6  7|        |34  PA6 (AI 6 / D25)
//   SCK (D 7) PB7  8|        |33  PA7 (AI 7 / D24)
//             RST  9|        |32  AREF
//             VCC 10|        |31  GND
//             GND 11|        |30  AVCC
//           XTAL2 12|        |29  PC7 (D 23)
//           XTAL1 13|        |28  PC6 (D 22)
//  RX0 (D 8)  PD0 14|        |27  PC5 (D 21) TDI
//  TX0 (D 9)  PD1 15|        |26  PC4 (D 20) TDO
//  RX1 (D 10) PD2 16|        |25  PC3 (D 19) TMS
//  TX1 (D 11) PD3 17|        |24  PC2 (D 18) TCK
//  PWM (D 12) PD4 18|        |23  PC1 (D 17) SDA
//  PWM (D 13) PD5 19|        |22  PC0 (D 16) SCL
//  PWM (D 14) PD6 20|        |21  PD7 (D 15) PWM
#define NUM_DIGITAL_PINS            24
#define NUM_ANALOG_INPUTS           8
#define analogInputToDigitalPin(p)  ((p < 7) ? (p) + 24 : -1)
#define digitalPinHasPWM(p)         ((p) == 3 || (p) == 4 || (p) == 12 || (p) == 13 || (p) == 14 || (p) == 15 )
#define PA 1
#define PB 2
#define PC 3
#define PD 4
#define PE 5
#define PF 6
#define PG 7
#define PH 8
#define PJ 10
#define PK 11
#define PL 12
#ifdef ARDUINO_MAIN
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] =
        NOT_A_PORT,
        (uint16_t) &DDRA,
        (uint16_t) &DDRB,
        (uint16_t) &DDRC,
        (uint16_t) &DDRD,
const uint16_t PROGMEM port_to_output_PGM[] =
        NOT_A_PORT,
        (uint16_t) &PORTA,
        (uint16_t) &PORTB,
        (uint16_t) &PORTC,
        (uint16_t) &PORTD,
const uint16_t PROGMEM port_to_input_PGM[] =
        NOT_A_PORT,
        (uint16_t) &PINA,
        (uint16_t) &PINB,
        (uint16_t) &PINC,
        (uint16_t) &PIND,
const uint8_t PROGMEM digital_pin_to_port_PGM[] =
        PB, /* 0 */
        PB,
        PB,
        PB,
        PB,
        PB,
        PB,
        PB,
        PD, /* 8 */
        PD,
        PD,
        PD,
        PD,
        PD,
        PD,
        PD,
        PC, /* 16 */
        PC,
        PC,
        PC,
        PC,
        PC,
        PC,
        PC,
        PA, /* 24 */
        PA,
        PA,
        PA,
        PA,
        PA,
        PA,
        PA  /* 31 */
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] =
        _BV(0), /* 0, port B */
        _BV(1),
        _BV(2),
        _BV(3),
        _BV(4),
        _BV(5),
        _BV(6),
        _BV(7),
        _BV(0), /* 8, port D */
        _BV(1),
        _BV(2),
        _BV(3),
        _BV(4),
        _BV(5),
        _BV(6),
        _BV(7),
        _BV(0), /* 16, port C */
        _BV(1),
        _BV(2),
        _BV(3),
        _BV(4),
        _BV(5),
        _BV(6),
        _BV(7),
        _BV(7), /* 24, port A */
        _BV(6),
        _BV(5),
        _BV(4),
        _BV(3),
        _BV(2),
        _BV(1),
        _BV(0)
const uint8_t PROGMEM digital_pin_to_timer_PGM[] =
        NOT_ON_TIMER,   /* 0  - PB0 */
        NOT_ON_TIMER,   /* 1  - PB1 */
        NOT_ON_TIMER,   /* 2  - PB2 */
        TIMER0A,        /* 3  - PB3 */
        TIMER0B,                /* 4  - PB4 */
        NOT_ON_TIMER,   /* 5  - PB5 */
        NOT_ON_TIMER,   /* 6  - PB6 */
        NOT_ON_TIMER,   /* 7  - PB7 */
        NOT_ON_TIMER,   /* 8  - PD0 */
        NOT_ON_TIMER,   /* 9  - PD1 */
        NOT_ON_TIMER,   /* 10 - PD2 */
        NOT_ON_TIMER,   /* 11 - PD3 */
        TIMER1B,        /* 12 - PD4 */
        TIMER1A,        /* 13 - PD5 */
        TIMER2B,        /* 14 - PD6 */
        TIMER2A,        /* 15 - PD7 */
        NOT_ON_TIMER,   /* 16 - PC0 */
        NOT_ON_TIMER,   /* 17 - PC1 */
        NOT_ON_TIMER,   /* 18 - PC2 */
        NOT_ON_TIMER,   /* 19 - PC3 */
        NOT_ON_TIMER,   /* 20 - PC4 */
        NOT_ON_TIMER,   /* 21 - PC5 */
        NOT_ON_TIMER,   /* 22 - PC6 */
        NOT_ON_TIMER,   /* 23 - PC7 */
        NOT_ON_TIMER,   /* 24 - PA0 */
        NOT_ON_TIMER,   /* 25 - PA1 */
        NOT_ON_TIMER,   /* 26 - PA2 */
        NOT_ON_TIMER,   /* 27 - PA3 */
        NOT_ON_TIMER,   /* 28 - PA4 */
        NOT_ON_TIMER,   /* 29 - PA5 */
        NOT_ON_TIMER,   /* 30 - PA6 */
        NOT_ON_TIMER   /* 31 - PA7 */
#endif
#endif
PortC pins are D16 to D23, so you seem to be on the right track.
I do the same all the time with 1284Ps, which has same pinout but twice the memory. Not really sure why the pinMode is not working for your device.
thanks you for your help! :slight_smile:
I will keep to try to solve it but maybe i will pass to 1284P. Not really interested in so much memory but the price is quite the same.
Yes, and 1284P has dual hardware serial ports, which is not on all versions of 644.
See this for adding 1284P support the IDE:
My boards use the Bobuino pinout to keep max compatibility with Unos:
D0/D1 for serial, D10-11-12-13 for SPI, jumpers to allow I2C or A4/A5 to be on D18/D19, or I2C can be separated.
You can see the specifics in my schematics or in the pins_arduino.h variants.
Searching for a solution that not include spend more money i have found out this:
http://www.leonardomiliani.com/2012/aggiungere-il-supporto-per-gli-atmega644p1284p-allarduino-ide-1-0-1/
Bootloader looks nice and solve the problem of the perpetual current drain from pins 24/27 but i'm not able to upload sketch on my 644 via serial port. There are some users that talk about solve this problem but for my use is enought that uploading work fine with ISP.
Thanks you for help. :smiley:
