Hello everyone,
I want to buy a 7" inch touch display for my project with an Arduino Mega, Ethernet shield and EasyVR shield.
I found this 7 inch LCD Module w/Optional Capacitive Touch Screen Panel,I2C/SPI that I understand works with Arduino and seens at a good price with the RA8875 driver.
I have doubts about the options I have to buy it, mainly about the capacitive touch x resistive touch.
But with everything else too, including the:
Interface: Pin Header Connection Parallel, I2C, 3 Wire SPI, 4 Wire SPI or the FFC? I read some where in the forum people using the 4 Wire SPI, that is the easiest to use? Which would be faster? I will be mostly showing of weather informations, using it as a alarm clock, and with some "floor blueprints" that can be done with simple squares buttons. So, probably not loading alot of images, just a sun, a moon, a cloud, to illustrate the weather. The response will be badly? I saw some people saying about 1 minute to load up some images.
Power Supply: I think should be 5V since I will power it from the Arduino, right?.
Font Chip: I don't know the diference between them ER3300-1 / ER3301-1 / ER3303-1 / ER3304-1.
Can I have some advice please???
As I said, mostly about the capacitive x resistive touch, which is better documented? Which is easier to use?
I'm not a newbie, but still learning on the fly, already did some cool things, but in eletronics I stil don't get a lot of things, I just want to make sure to buy the correct product, I do accept indications of better products too, I saw the Sainsmart ones, that is a bit more pricey, but not out of my range.
