7 segment 4 digit display time counter
so I would like to make a time counter (minutes and seconds) with a 7 segment 4 digit siplay but I am having some problems. My idea was to declare 4 values, one for each segment like so:
a - 1. segment
b - 2. segment
c - 3. segment
d - 4. segment
Every value would firstly be declared as 0 and every second D would get bigger by one. When D gets equal to 10, C would rise by one and D would reset to zero. Proces This way I would have to write code for 36 different scenarios instead of 6000.
I’ve tried something I thought would work but I have a problem. 1st segment is lit up all the time but others only turn on for a split second to display their value. I know this type of display has to switch between segents very fast to display numbers on all of them but I don’t know how to make it work without a 1 second delay (D gets bigger by 1 every time the code runs, this means every second due to delay(1000)).
Idea I have is to set a delay to 1 instead of 1000 and make D bigger by 0.001 every time the loop runs. This way all segments should work properly and D would get bigger by 1 every second, making it count correctly.
I don’t know if my idea would work and don’t know how to code it so any help would be much appreciated. I am new to Arduino and this is my first project that I am not literraly copying someone elses code.
I’ve attached both Arduino IDE and Pletformio VSCode files.
#include <Arduino.h> // I am using Platformio plugin in VSCode
int pinDOT = 3; // Declares pins to their segments or common pins on the display.
int pinA = 11;
int pinB = 7;
int pinC = 4;
int pinD = 2;
int pinE = 1;
int pinF = 10;
int pinG = 5;
int pinC1 = 12;
int pinC2 = 9;
int pinC3 = 8;
int pinC4 = 6;
int addon = 1; // Addon - gets added to a variable every time a second passes.
int a; // Variables that are used to write the time on display. A & B for minutes, C & D for seconds like so: AB:CD.
int b; // Variables are only introduced and not declared because they are declared lower so there is no need to scroll up to change them.
int c;
int d;
void C1() {
digitalWrite(pinC1, HIGH);
digitalWrite(pinC2, LOW);
digitalWrite(pinC3, LOW);
digitalWrite(pinC4, LOW); // C1() - C4() tells Arduino on which part of the display the number should be written.
void C2() {
digitalWrite(pinC1, LOW);
digitalWrite(pinC2, HIGH);
void C3() {
digitalWrite(pinC3, HIGH);
void C4() {
digitalWrite(pinC4, HIGH);
void N0() {
digitalWrite(pinA, LOW);
digitalWrite(pinB, LOW);
digitalWrite(pinC, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
digitalWrite(pinG, HIGH);
digitalWrite(pinDOT, HIGH); //N0() - N9() tells Arduino which number to write on the display.
delay(1);
void N1() {
digitalWrite(pinA, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
delay(1);
void N2() {
digitalWrite(pinC, HIGH);
digitalWrite(pinG, LOW);
delay(1);
void N3() {
delay(1);
void N4() {
delay(1);
void N5(){
digitalWrite(pinB, HIGH);
delay(1);
void N6(){
delay(1);
void N7() {
delay(1);
void N8() {
delay(1);
void N9() {
delay(1);
void DOT() {
digitalWrite(pinDOT, LOW); // Tells Arduino to display a dot on the display. Usually combined with a number like so: N0(); DOT();
pinMode (pinA, OUTPUT);
pinMode (pinB, OUTPUT);
pinMode (pinC, OUTPUT);
pinMode (pinD, OUTPUT);
pinMode (pinE, OUTPUT);
pinMode (pinF, OUTPUT);
pinMode (pinG, OUTPUT);
pinMode (pinDOT, OUTPUT);
pinMode (pinC1, OUTPUT);
pinMode (pinC2, OUTPUT);
pinMode (pinC3, OUTPUT);
pinMode (pinC4, OUTPUT); // Sets all the pins to output mode.
a = 0; // Declares values. Explenation at the start of the code.
b = 0;
c = 0;
d = -1; // D is set to -1 so it starts with 0 when loop runs for the first time.
d = d + addon; // Adds 1 to the current value of D. First time the loop runs it is equal to 0 after addition is completed.
if (d == 10) // If D reaches 10, reset it to 0 and add 1 to the current value of C. Meaning when D is equal to 10,
{ // write 1 and 0 on C3 and C4 (you can’t display 10 with one digit).
d = 0;
c = c + addon;
if (c == 6) // If C reaches 6, reset it to 0 and add 1 to B. 6 because 1 minute has 60 seconds.
c = 0;
b = b + addon;
if (b == 10) // If B reaches 10, reset it to 0 and add 1 A.
b = 0;
a = a + addon;
if (a == 10) // If A reaches 10, reset all values to 0 - restart counter.
a = 0;
b = 0;
c = 0;
d = 0;
C4(); // Tells Arduino to write a number on 4th segment. Number is the same value D is.
if (d == 0)
N0();
else if (d == 1)
N1();
else if (d == 2)
N2();
else if (d == 3)
N3();
else if (d == 4)
N4();
else if (d == 5)
N5();
else if (d == 6)
N6();
else if (d == 7)
N7();
else if (d ==
N8();
else if (d == 9)
N9();
C3(); // Tells Arduino to write a number on 3rd segment. Number is the same value C is.
if (c == 0)
N0();
else if (c == 1)
N1();
else if (c == 2)
N2();
else if (c == 3)
N3();
else if (c == 4)
N4();
else if (c == 5)
N5();
else if (c == 6)
N6();
C2(); // Tells Arduino to write a number on 2nd segment. Number is the same value B is.
if (b == 0)
N0();
else if (b == 1)
N1();
else if (b == 2)
N2();
else if (b == 3)
N3();
else if (b == 4)
N4();
else if (b == 5)
N5();
else if (b == 6)
N6();
else if (b == 7)
N7();
else if (b ==
N8();
else if (b == 9)
N9();
C1(); // Tells Arduino to write a number on 1st segment. Number is the same value A is.
if (a == 0)
N0();
else if (a == 1)
N1();
else if (a == 2)
N2();
else if (a == 3)
N3();
else if (a == 4)
N4();
else if (a == 5)
N5();
else if (a == 6)
N6();
else if (a == 7)
N7();
else if (a ==
N8();
else if (a == 9)
N9();
delay(1000); // Waits for 1 second - this means D gets bigger by 1 every second.
main.cpp (7.74 KB)
Counter.ino (7.73 KB)
if you delay for 1 sec, only the last digit will be displayed. you need to display each digit roughly an equal amount of time for equal brightness.
i think a refresh rate of 1/30th of a second is a decent starting point. that mean display each digit for ~8ms.
your code would be much smaller if you could put each digit to be displayed in an array and in a for loop call the segment display routine for the value and the corresponding digit enable routine (e.g. C1()). and you could make this much small still
gcjr:
Do you know any good guides on how to use decimal values? I've looked at some but didn't quite understand how to use the float function so i dont know how to make a delay shorter without messing up time.
I know my code is still a bit long but firstly I would like to make everything work and then I'll play around with minimizing it. Thanks for the tip though :slight_smile:
to find a specific digit, can you do
int ((val / 10^n) % 10)   n=0,1,...
i think a good start, would be to correctly display 1234
See if this works and what you can get from it. It multiplexes the four digits as described above.
I didn’t add the “dot” and may have gotten the order of the digits wrong or something. Compiles, not tested…
//protos
void UpdateDisplayDigits( void );
void UpdateCount( void );
void UpdateDisplay( void );
#define NUM_DIGITS          4           //#     number of digits to display
#define NUM_SEGS            7           //#     number of discrete segments
#define TIME_PER_DIGIT      8333ul      //uS    time per digit in muxed display
#define COUNT_INTERVAL      1000ul      //mS    time per countdown tick
const byte pinDOT = 3; // Declares pins to their segments or common pins on the display.
const byte pinA = 11;
const byte pinB = 7;
const byte pinC = 4;
const byte pinD = 2;
const byte pinE = 1;
const byte pinF = 10;
const byte pinG = 5;
const byte pinC1 = 12;
const byte pinC2 = 9;
const byte pinC3 = 8;
const byte pinC4 = 6;
const byte Anodes[] =
    pinA,
    pinB,
    pinC,
    pinD,
    pinE,
    pinF,
    pinG
const byte Cathodes[] =
    pinC1,
    pinC2,
    pinC3,
    pinC4
unsigned int
    Countdown;
byte Digits[NUM_DIGITS];
// digitCodes; which of the 7-segs is on to display a given digit
//  in this table: 1 = segment on
const byte digitCodes[] =
    //GFEDCBA  Segments
    B00111111,  // 0
    B00000110,  // 1
    B01011011,  // 2
    B01001111,  // 3
    B01100110,  // 4
    B01101101,  // 5
    B01111101,  // 6
    B00000111,  // 7
    B01111111,  // 8
    B01101111   // 9
    byte
        idx;
    //init the segs
    for( idx=0; idx<NUM_SEGS; idx++ )
        pinMode( Anodes[idx], OUTPUT );
        digitalWrite( Anodes[idx], HIGH );
    }//for
    //init the cathodes
    for( idx=0; idx<NUM_DIGITS; idx++ )
        pinMode( Cathodes[idx], OUTPUT );
        digitalWrite( Cathodes[idx], LOW );
    }//for
    Countdown = 120;        //2 minute start (2 * 60-seconds == 120-sec)
    UpdateDisplayDigits();
}//setup;
void loop( void )
    UpdateDisplay();    //must run very frequently
    UpdateCount();
}//loop
    static unsigned long
        timeCount=1000ul;
    unsigned long
        timeNow;
    //once per second decrement the Countdown value until it reaches zero
    timeNow = millis();
    if( (timeNow - timeCount) >= COUNT_INTERVAL )
        timeCount = timeNow;
        if( Countdown > 0 )
            Countdown--;
    }//if
}//UpdateCount
    byte
        temp;
    //break countdown into its constituent digits
    temp = (byte)(Countdown / 60);
    Digits[3] = temp / 10;
    Digits[2] = temp - (Digits[3] * 10);
    temp = (byte)(Countdown - (temp * 60));
    Digits[1] = temp / 10;
    Digits[0] = temp - (Digits[1] * 10);
    //for( temp = 0; temp<NUM_DIGITS; temp++ )
    //    Serial.print( Digits[3-temp] );
    //Serial.println();
}//UpdateDisplayDigits
        timeDigit = 0;
    unsigned long
        timeNow;
    byte
        dVal,
        digitMask;
    static byte
        lastDigitIndex = 3,
        digitIndex = 0;
    //to achieve 30Hz on 4 digits means
    //  t0   t1   t2   t3
    //  0----1----2----3----0...
    //  t0+t1+t2+t3 <= 33.33mS or 33333uS
    //  and
    //  t0=t1=t2=t3=8333.25; use 8333uS per digit (TIME_PER_DIGIT)
    timeNow = micros();
    if( (timeNow - timeDigit) >= TIME_PER_DIGIT )
        timeDigit = timeNow;
        //turn off the current cathode
        digitalWrite( Cathodes[lastDigitIndex], LOW );
        //get the segment mask value of the digit to display in this time slice
        dVal = digitCodes[Digits[digitIndex]];
        digitMask = 0x01;
        for( byte i=0; i<7; i++ )
            digitalWrite( Anodes[i], (dVal & digitMask) ? LOW:HIGH );
            digitMask << 1;
        }//for
        //Serial.println( dVal, BIN );
        //turn on the current cathode
        digitalWrite( Cathodes[digitIndex], HIGH );
        //remember current as last
        lastDigitIndex = digitIndex;
        //bump current to next; at last digit, return to first
        digitIndex++;
        if( digitIndex == 4 )
            digitIndex = 0;
    }//if
}//UpdateDisplay
