my goal in the end is that it just counts up
The numver of the 7-segment ist:
LTC4622G
Can anyone give me the solution, maybe draw it or something? I won't understand it otherwise but I'm really trying. Maybe then also a bit of code that a certain number is displayed. I know you learn less that way. But thanks for all the answers
Vieleicht es auch jemand deutsch und kann es mir besser erklären
Note the transistors to supply the current, the pins alone are insufficient, and could end up damaging your Arduino. Note that the current limiting resistors are on the cathode.
Also you might not be familiar with the depiction of a wiring bus, those thick wires. Think of the thich wires as a bundle of wires and you fish out the required wire name for each. It makes the schematic a lot neater and simpler to read,
Should have, not need. Using a single resistor is a common deliberate hack. It makes the segment illumination uneven, but some people don't care about it.
