I am trying to control a 4 digit 7 segment display (without a driver) directly from an arduino nano.
I have realised theres a limitation to the combination of LED’s I can have on/off. For example If I want the first digit to display the number “1” and the second digit to display the number “2”, thats not possible. I have attached the 7 segment display circuit diagram.
gazitron:
I just realised there's a thing called multiplexing
Great discovery.
OK, now you can do some experimentation with multiplexing code. Note - you need a 1k resistor in each of the eight cathode lines which you connect to the Nano (which is far better than the UNO for this sort of experimentation, generally with a "solderless breadboard").
It is good fun but do not consider using that in a design when you want to use it for a serious project. 7-segment display modules using MAX7219s or (not so useful) TM1637s are inexpensive and perform all the multiplexing for you and provide much higher brightness - I specified 1k resistors for a reason, nothing lower in value.
Also, practice downloading the graphics themselves from websites to pass on rather than screenshots. Do you see what funny thing happened to the diagram?
